Hi,
I'm just getting started with Blu Ray authoring and burning and have a problem I can't fix. I'm taking HD video sent from my TIVO (using kmttg to stream to pc) and then using Video ReDo to cut commercials. A MPEG2 file is created that I want to author and simply burn to a Blu Ray disc without encoding again and losing picture quality. My problem is that some of the discs I've created will have very choppy video when played back on my Samsung player. I notice it in particular during fast moving scenes. I've tried Cyberlink Power Director 10, MulitAVCHD 4.1, and tsMuxer to author the discs from the same MPEG2 file and get the choppy video from each one. The strange thing is that the MPEG2 source file will play back without any choppiness using VLC player.
I believe that the issue is related to the bitrate, but don't know how to determine it for sure. About half of my TIVO to Blu Ray conversions have gone very smoothly without any reencoding and there is no choppy picture problem. It's a sporadic problem and that makes it more frustrating to try to determine the root cause. I use ImgBurn to burn discs at 4x and Optical Quantum 25GB discs. I have not had a problem with any burned disc not playing in my player.
My questions are:
1. What can I do to determine if there is a problem with the video before I start the authoring or burning process?
2. What is the best way to fix the video problem and maintain the best possible picture quality for the Blu Ray?
3. If it's a burning issue, what needs to be done to solve the problem?
Thanks for your help.
Mediainfo:
General
Complete name : L:\TIVO\Singin in the Rain.mpg
Format : MPEG-PS
File size : 9.49 GiB
Duration : 1h 42mn
Overall bit rate : 13.3 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Duration : 1h 42mn
Bit rate mode : Variable
Bit rate : 12.6 Mbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.202
Stream size : 8.98 GiB (95%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Muxing mode : DVD-Video
Duration : 1h 42mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 328 MiB (3%)
Text
ID : 224 (0xE0)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
problems splitting mkv files then playing on lg blu ray
By julie_152 in forum Video ConversionReplies: 6Last Post: 15th Jan 2013, 05:54 -
Do these blu ray products rip blu ray movie files on to your computer?
By missyxxmischa in forum Authoring (Blu-ray)Replies: 6Last Post: 11th Nov 2012, 18:01 -
Problems authoring Blu-Ray from HD Camcorder files
By Arnold_Layne in forum Authoring (Blu-ray)Replies: 3Last Post: 30th Jun 2011, 11:35 -
Blu-Ray which is better MPEG2 or H.264
By lenti_75 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2010, 12:14 -
Blu-ray discs created in 1280x720 60p
By Persistence in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jun 2009, 17:05
