Hello,
I came across with this problem several times. Especially when I reinstall the codec package, Subtitle Workshop 2.51 becomes incapable of working with MP4 and MKV videos. I think there is not any clear explanation on how to solve this issue. This is a short and clear solution to fix both MKV and MP4 preview problem with Subtitle Workshop 2.51 :
For Win7 :
1- Install K-Lite package K-Lite Codec Package (Clear install)
2- Start>All Programs>K-Lite..>Configuration>ffdshow video decoder>codecs
set Raw video (at end of the list) to YV12
3- Start>All Programs>K-Lite..>Configuration>DirectVobS>General
set Loading to Do not load
This it!
Hi,
I found this thread via Google, and I must say it was of great help, saving me a lot of troubleshooting!
However, instead of installing K-Lite Codec Pack, I just installed ffdshow and Haalis Media Splitter. I also had to set Raw video to "All supported", as YV12 didn't work for me. Anyone following this tips, do observe that you should undo the settings afterwards, as it will degrade video performance. -
I tried both, none worked.
I understand that only "ffdshow" is needed for displaying mp4.
I tried different configurations, very complicated options, I don't understand.
Can some explain it for dummies, thanks!
I just want to see MP4 in Subtitle Workshop...
Thanks again
Caban -
Subtitle Workshop not showing mkv files during preview
By tuna1013 in forum SubtitleReplies: 27Last Post: 26th Jun 2014, 14:57 -
SOLVED: preview, out of sync subtitles behind Subtitle Workshop....
By bahjan in forum SubtitleReplies: 0Last Post: 10th Mar 2012, 06:27 -
Problem subtitle edit with MKV & MP4
By whitebeard in forum SubtitleReplies: 2Last Post: 19th Jun 2011, 09:45 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 23:16 -
video preview problem with submagic and stubtitle workshop
By ecc in forum SubtitleReplies: 0Last Post: 27th Jan 2008, 03:48
