VideoHelp.com Forum
  1. ok.. i captured some video off a digital camera using a belkin fireware card that i purchased 2 days ago.I converted it to Mpeg1 format burnt it to a cd.. when i played it the video was very good.But the sound kept breaking..as in .. its would play for 1 second . then for 2 seconds u hear nothing .its been like that for the whole time i played it! i tried reconverting with better options..still didnt work welll...i tried burning a video that i download on kazaa .and it works fine! HELP!!!!!!!!!!!!!!!
    P.S the stuff i capturedo on the computer works fine in widows media player!
    :evil: How may times are you going to ask the same question, You just posted the same question 21 minutes ago. Please give us time to look at the messages, time to decode your problem, and even more time to come up with an answer for you, i.e. 24-36 hours. :evil:
    Now from what I understand you are trying to say is anything you download from the web can be converted and plays the audio correctly?
    Anytime you try to capture from your capture card the audio drops out?
    If this is correct then you have a problem with you capture card installation(logical deduction)( I love logic, it fixes everything).
    You will need to check the following (check the how to guides to the left they tell you the same thing)
    1. Check for IRQ conflicts.
    2. Check your sound card for input settings.
    3. Check and see if your capture software is compatible with your O/S.
    4. Read through your installation manual and follow the directions to the letter, you may have missed a very important step.
    5. If all the above fail post another message that explains ALL your system information andEXACTLY what you did so far to try to fix the problem.
    6. 8) Don't call us, We'll call you. 8)
  3. thanks alot for replying . and sorry for the second message :cry:
    what is the logical thing ?
    and if it is my card . how come it works well in windows media player . its perfect in windows media player.
    Need more information to try to figure out what your problem is. Please answer the following questions so we can figure out where your problem is.
    1. After you capture your video with the firewire card do you preview the video with windows media player? Does it play correctly?
    2. What burning software are you using(Nero,EasyCD, etc)?
    3. What O/S are you running (XP,2k,98,etc)?
    4. Did you check and make sure no other cards are using the same IRQ as the firewire card?
    5. What software are you using for the conversion to Mpeg-1?
    6. What are the settings you are using for capture and Mpeg-1 conversion?
    7. What is your system( CPU,m/b, memory,hds,etc)?
    8. If your writing software allows it do you preview the movie before you write it to CD?
  1. Problem with DivX yet works in Windows Media Player
    By tmundrill in forum Software Playing
    Last Post: 18th Oct 2009, 06:44
  2. Sound works on Pc but not on Dvd player
    By Rogert in forum Audio
    Last Post: 7th Jun 2008, 07:22
  3. DVDRW works fine on PC, not on DVD Player
    By Koopzer in forum Newbie / General discussions
    Last Post: 21st Apr 2008, 02:54
  4. Replies: 2
    Last Post: 14th Jan 2008, 13:57
  5. vcd playback - flickering picture on one dvd player, fine on another
    By i_ming in forum Newbie / General discussions
    Last Post: 21st Oct 2007, 07:41
