I just got a new LG Bluray Burner, I was able to burn on my old dvd burner and Sata HardDrive, after I bought this BDburner I Installed 2 SSDs in Raid 0, and installed a fresh windows copy, Installed video,chipset drivers, and updated the firmware on the drive. I am able to Rip Movied from Bluray to Dvd Files with Dvdfab, but when I try burning them with dvdfab It hangs on about 80% and it hangs and it never ends, it doesn't even start burning, it just ends converting. I also do alot of Divx or Avi to Dvd with ConvertX to Dvd. this software is able to convert and it seems it finishes but the software never finishes and the drive keeps on spinning, I have to shut it down, but I am able to play the dvd fine. I've tried these methods with an external drive and same thing happens. The only way I can burn my DVD Folders is with the software that came with the drive which is Cyberlink, and the media dvd are Phillips DVD-R. Hopefully you guys can help, thank you.!!!!
Try using IMGBURN to burn your discs.
http://www.imgburn.com/index.php?act=download
Will Any DVD HD conflict with DVDFab Bluray Ripper?
By shadowdrifter in forum Newbie / General discussionsReplies: 6Last Post: 9th Jun 2017, 14:55 -
DVDFab's BD > DVD converter won't play properly on standalone...
By takearushfan in forum Authoring (DVD)Replies: 9Last Post: 24th Oct 2012, 22:36 -
DVDfab Bluray-to DVD
By cavusozkan in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Jun 2011, 10:26 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 00:16 -
DVD's/CD's won't finalize HELP
By dude-nl in forum DVD & Blu-ray WritersReplies: 19Last Post: 10th Dec 2008, 14:31
