Hi guys,
here it is the issue: some DVB-T channels switch from 4:3 to 16:9 format during commercial breaks but they don't return to the correct format just when the show (or whatever) starts again, only after 1 or 2 seconds (sometimes even more), this resulting in a certain amount of frames with wrong AR at the beginning of the new "segment" after a break.
My goal is to author a DVD and I'm pretty sure this "mixed aspect ratio" will be a problem.
Is there a way to fix this thing so that all the frames have the same AR?
Results 1 to 16 of 16
Thread: 16:9 frames in a 4:3 DVB
Why would it be a problem? They all have the same resolution, don't they, 720x576 or whatever? Just set the DAR in your MPEG-2 encoder.
If you're not reencoding then yes, you may have a problem. Something like DVDPatcher should be able to give the whole thing the same DAR. -
Along with wrong flags, it sometimes happens in the very beginning of a 4:3 broadcast or just after a commercial, that about 100 frames have wrong proportions (after AR flags cure). I usually have to crop/resize/replace those frames (DGIndex-Avisynth-CCE-MVW). An example: recent 'Rolling Stones at the BBC' broadcast (problems in intro part: pillarboxed -> true 4:3 @ everything flagged as 16:9).
Thanks for replying.
@manono
Actually I won't re-encode since Project-X gives me a .m2v stream.
I don't know DVDPatcher, it could be the right tool to use, I'll give it a look.
@Alex_ander
I don't know exactly how you "replace" those frames but from what I read re-encoding is involved and I would like to avoid it if possible. -
*** Now that you have read me, do some other things. ***
Thanks to you too [_chef_]. I realized that I forgot to mention an important point: my DVB-T receiver records the broadcast in a series of separate files (0001.MPG, 0002.MPG, ..., 000n.MPG) so the 16:9 frames can be in any of them. I don't know if DVDPatcher can handle this. Anyway I haven't had the time to try yet.
For aspect ratio, you should try in projectX->presetting to set DAR to the aspect ratio of your movie ,I think it should set a fixed aspect ratio to your recording instead of a varying one (The adds would have the wrong aspect ratio but does that matter ?).
If I remember well,ProjectX can join multiple mpeg2 files to one single file ,I think I made that with .TS and .VOB files but not .MPG
Edit : forgot something: some DVB broadcasts use resolution like 544*576 that are not compliant to DVD ,you will have to re-encode in that case.Last edited by misermidas; 9th Jan 2013 at 10:43.
Thanks misermidas.
I will give it a try, as soon as I'm able to find the time (don't know when actually).For aspect ratio, you should try in projectX->presetting to set DAR to the aspect ratio of your movie ,I think it should set a fixed aspect ratio to your recording instead of a varying one (The adds would have the wrong aspect ratio but does that matter ?).
And no, not only the ads have the wrong AR, some frames of the "thing" (movie or whatever) too, I think it would take a lot of working to fix those frames (extract, resizing and reinserting them someway) so I think I'll live with that.
It can. I load the series of MPEG files into ProjectX, cut out the ads and demux, it gives me two files: .m2v and .mp2, ready for authoring.If I remember well,ProjectX can join multiple mpeg2 files to one single file ,I think I made that with .TS and .VOB files but not .MPG
Never happened so far (luckily).some DVB broadcasts use resolution like 544*576 that are not compliant to DVD ,you will have to re-encode in that case. -
My HD decoder has AR settings at "auto", 16:9, letterbox, pan and scan, etc.
Auto follows what the TV station sets, but often that's wrong (at least for my primitive TV), and I end up with something both letterboxed and pillarboxed, so I manually set it.
If you can find a similar setting see if you can just fix it to widescreen or 4:3 regardless. -
Problem is that the broadcasters keep switching from one AR to another so (I think) I'll end up with some wrong frames no matter how I set the receiver.If you can find a similar setting see if you can just fix it to widescreen or 4:3 regardless.
I'll look to see if there is a similar option on my receiver, but I'm afraid this is not the solution since the problem is in the broadcast itself. -
Yeah, there are standards and most of the broadcasters give a damn about it... that leads to problems which Instand Martian describes...
And even each reception device will handle such non-standard stuff differently..its a mess.
IM, have you tried with DVDlab (even trial version) or TMPGENC Author?*** Now that you have read me, do some other things. *** -
No I haven't. DVDlab and TMPGENC Author are authoring software, I don't know how (and if) they could be used to fix this issue.
Yes, that's what I want but I start authoring only after I have all the assets ready and flawless.
What I mean is I don't know if they can be used to fix this kind of problem. -
Martian,
I use Project-X for pre-processing my (SD) recordings, too. There is a setting for aspect ratio in the video section which affects the overall properties of the demuxed output files, and there is an aspect ratio setting in the editing window, which activates some kind of A/R filter.
If I demux a mixed A/R TS recording, which has 4:3 video (Columbo, Kojak, other cool 70s stuff) and 16:9 teasers/commercials, only true 4:3 frames are kept, all other frames are discarded on the way. I can live with losing some 4:3 frames, which were incorrectly flagged as 16:9. Project-X is capable of getting rid of each and every 16:9 frame automatically, which gives me a clean 4:3 stream.
After that I use Cuttermaran to trim and manually remove any leftover teaser/commercial frames where the 4:3 AR flag was switched on/off too early/late. -
Lowlander, thanks a lot for your helpful reply, I didn't know that. It could be the solution in most of the cases but sometime the number of "wrong" frames is too high to simply cut them away or even worse, they keep switching from one AR to another for a few seconds into the show, after a commercial break. In that case I think I'll have to live with it and leave the frames as they are, but I'll keep in mind your tip, it's very useful. Thanks again.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum CapturingReplies: 12Last Post: 17th Aug 2011, 22:33 -
DVB-S/DVB-S2 Satellite Receiver with direct HD,SD/SDI output not HDMI
By rahemeen in forum DVB / HDTVReplies: 1Last Post: 19th May 2011, 05:38 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
mencoder: seeking to frames (or cropping start frames)
By manchurian_candidate in forum LinuxReplies: 3Last Post: 13th Dec 2010, 08:53 -
Cutting Mp4 between I-frames, replacing some frames
By eymerich in forum EditingReplies: 4Last Post: 29th Jul 2009, 08:41
