I've been using MeGUI to encode all my videos and today I encoded a video with the mkv container then using the exact same video with the exact same encoding settings I encoded into the MP4 container and it comes out about 28 MB less than the MKV. Anyone know why it's smaller?
Something is wrong, unless the video is large. The margin of difference is much less than 0.1 - 0.2%
Did you account for audio or other streams? Same processing steps ? What does the log file say ? What does mediainfo say about the 2 versions (view=>text) -
BTW I'm curious why you would do this in the first place ? (encode the same source using the same settings, just different container)
You could have just re-muxed into different container (no quality loss, many times faster) - doing this you can also prove to yourself that the filesize will be very similar -
ASSUMING "nothing has gone wrong" in the muxing processes themselves, it's possible that the (apparent) problem was caused by the settings in the Matroska muxer. When you define the so-called "cues" for ALL audio/video frames, the container overhead gets significantly bigger.
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 10:56 -
need to put content of FLV container into MP4 container
By arraboy in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2012, 19:52 -
What's the most "Device Compatible" container? is it, .mp4 or .mkv?
By thezanny in forum Video ConversionReplies: 11Last Post: 3rd Jan 2012, 08:07 -
convert mkv(2audio/2txt) to mp4 or other container
By felix in forum Video ConversionReplies: 3Last Post: 14th May 2009, 08:04 -
How do you move files from .ogm container to .mkv container?
By VidHunter in forum MacReplies: 0Last Post: 8th Mar 2008, 18:19
