hello,
I just finished setting up my home theater system as best i can and my new epson projector is 3d ready. ive got a few movies (3D mkv rips) and i was wondering if i run those through my MVIX media player and throw on my 3d glasses will i have issues watching the film? i'd test but my screen wasnt shown up yet and still waiting for new receiver to show up as well. any help / advice would be greatly appreciated.
Results 1 to 9 of 9
Thread: epson 3d projector and 3d mkvs
as long as the projector has 3d sbs or o/u capability it should be ok. check the manual.
thanks aedipuss. i have to be 100% honest, i bought the projector on a recommendation by a friend as he has the same one. i am also "new" to the whole 3d wave. i didnt think i would get into it and probably wont, all depends on the quality of the 3d i guess. Are all 3d blurays that you can buy SBS? i see that some 3d is top/bottom, anagyph or SBS. thanks
Assuming you have a 3010 or better model Epson projector, where all 3D comes in via HDMI signalling...
All depends on what your "MVIX" media player can do and whether those "rips" are formatted correctly. I've never heard of MVIX, but it looks like a Boxee-style HTPC/mediacenter. Frome what I can tell, NONE of the MVIX products EXPLICITLY support 3D, meaning "acknowledge" the 3D formats and re-composite it into a format (HDMI-Frame Packing or HDMI-SbS or HDMI-T/B) that is automatically supported by your projector.
Without that support, what you will have to do is pre-format your files into "frame-compatible" (aka standard 2D-compatible) formats such as anamorphically squeezed SbS or T/B. Then the media player will play it just as if it was playing a standard 2D file (because for all intents and purposes, it IS a 2D file) and then you will have to MANUALLY turn on 3D and MANUALLY set the 3D format option to either SbS or T/B.
If you want a better experience, you'll either have to find a media player that specifically, explicitly supports 3D or get a 3D blu-ray player and watch real BD3Ds on it (not rips, which may have already been compromised).
BTW, when you get your reciever if it isn't already HDMI 1.4-compatible, you DO NOT want to put it in the chain in-between a "3D-aware" media player (assuming you get one) and your 3DTV/Projector, otherwise it will "tell" the media player that it only supports 2D and the media player will drop back into 2D mode, cancelling any Full-HD-3D benefit you might have gotten by upgrading your player. Put your receiver AFTER your TV/Projector in the chain (assuming the TV/Projector has enough HDMI ports and can "pass-through" the signal). If you can't do that, you'd have to get a HDMI 1.4/3D-aware splitter.
Scott -
cool. the receiver is a pioneer elite model with HDMI 1.4. i plan on plugging all the components into the A/V receiver (bluray player, media player, direcTV) and then using HDMI out to the projector, where i would normally plug into my tv in the old set up. but your saying to plug the media player directly into the projector? it has two hdmi inputs. Can i not just plug everything into the receiver and only run one output to the projector? sorry if im talking in circles.
thanks -
Quality comparison:- BD3D (3D blu-ray) = 1920 x 1080 x 2 views (L+R) @ 24p, or 1280 x 720 x 2 @ 50p/59.94p
- SbS = 960 x 1080 x 2 @ same rate, or 640 x 720 x 2 @ same rates, IOW 1/2 the quality
- T/B (aka O/U) = 1920 x 540 x 2 @ same rate or 1280 x 360 x 2 @ same rates, IOW 1/2 the quality (but with slightly better 3D depth)*
- Anaglyph = same as BD3D, but colors SEVERELY COMPROMISED! Plus, Anaglyph is actually OFTEN not a consumer option (plus you must specifically have the correct glasses for the color coding, e.g. Red/Cyan). IOW less than 1/2 the quality
BDs prior to the spec, and DVDs, could be a combination of SbS, T/B, Interlaced, or Anaglyph - there was no consensus. And none of those were Full-HD-3D, unlike BD3Ds.
* See my previous posts re: horizontal resolution as pertaining to depth resolutionLast edited by Cornucopia; 12th Dec 2012 at 17:55.
great..thanks alot for all your help guys. i greatly appreciate it.
Merging 2 mkvs into one
By leoficz in forum Video ConversionReplies: 8Last Post: 19th Apr 2012, 06:31 -
Do I have to buy an Epson Projector again ?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2010, 08:11 -
Joining MKVs
By Maajid in forum Video ConversionReplies: 0Last Post: 1st Aug 2010, 09:21 -
Help broadcasting from Canon GL2 to Epson Powerlite S5 projector
By flipzoso in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 31st Dec 2009, 15:51 -
My Epson EMP TWD10 DVD Projector
By GazBelfast in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Aug 2009, 12:44
