Portable Pix Map is a fairly standard format (though not as much as PNG), and VDub should be support importing PPM images as video frames (just like it already supports BMP, PNG, etc). I have a physics sim game with built in screen recording feature. However instead of exporting all frames to a single AVI file, it exports each one to a separate file, and that file is a PPM image. For some reason they don't use the more standard BMP file for these images. I've contacted this software's developer and asked him recode the screen recording function to output BMP instead, but he INSISTS on sticking with PPM. So to compile it into an AVI I'll need either Virtualdub's frame loader to have the capability added to it to be able to load PPM images, or I'll have to get all the images converted in another program, prior to importing them as frames in virtualdub. However if it is a two step process (convert then make AVI) it will take twice as long as if it could just natively load PPM images. Unfortunately, I don't know how to contact VDub's development team. Maybe you guys here at videohelp.com know how to contact them, and could pass my message onto them on my behalf.
you can submit a feature request at the vdub forums
http://forums.virtualdub.org/
ImageSource in avisynth supports ppm, you can load it into vdub that way -
Well don't waste your replying to me... use it on convincing Avery or Phaeron
Just my opinion - I'd argue there are better image formats , and nobody uses ppm . I suspect they will say the same thing -
No one uses PPM.
Virtualdub is open source. If you feel strongly that PPM should be supported, why not put the effort into writing something for it yourself?......
Does multiavchd or tsmuxer support .tp files as input sources?
By yoda313 in forum Video ConversionReplies: 8Last Post: 8th May 2010, 08:08 -
TMPGEnc Authoring Works 4 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 4th Mar 2010, 12:05 -
TMPGEnc MPEG Editor 3 updated with WTV input support
By gyoshi in forum Latest Video NewsReplies: 0Last Post: 3rd Mar 2010, 19:34 -
does procoder 3 support flv input for conversion?
By perfection in forum Video ConversionReplies: 2Last Post: 13th Sep 2008, 00:25 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 16:00
