Ive been playing AVI files on my Blu Ray for quite some time now via USB, however in one particular incident a movie is "Format unsupported", while other .avi files are not. Ive done countless USB plays on my player using AVI, and this certain avi file continues to be rejected. I've synced this particular movie to the usb just like I always have for every other movie.
My understanding is that AVI is a format, so why would this file be refused while the others weren't?
Closed Thread
AVI is a container and a variety of audio and video could be inside of it. Apparently this AVI has some audio and/or video your player doesn't like. How about posting a MediaInfo Tree file of the one that won't play?
This is the file that doesn't work. A working file is posted below this.
General
Complete name : C:\Users\Jawska\Videos\Lawless.2012.DvDRip.XviD-SWAXXON\Lawless.2012.DvDRip.XviD-SWAXXON.avi
Format : DivX
Format/Info : Hack of AVI
File size : 961 MiB
Duration : 1h 55mn
Overall bit rate : 1 160 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 1h 55mn
Bit rate : 1 035 Kbps
Width : 640 pixels
Height : 320 pixels
Display aspect ratio : 2.000
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.211
Stream size : 857 MiB (89%)
Title : Video
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 55mn
Bit rate mode : Constant
Bit rate : 112 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 92.7 MiB (10%)
Alignment : Aligned on interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 512 ms
Title : Audio
Text #1
Format : DivX Subtitle
Codec ID : DXSB
Codec ID/Info : Subtitle in AVI from DivX networks
Width : 720 pixels
Height : 576 pixels
Bit depth : 4 bits
Stream size : 2.07 MiB (0%)
Title : Subtitle - en-xx;02
Text #2
Codec ID : DXSB
Width : 720 pixels
Height : 576 pixels
Bit depth : 4 bits
Stream size : 1.40 MiB (0%)
Title : Subtitle - sv-xx;02
Whereas this file works. Looks like its the "Hack of AVI" format.
General
Complete name : C:\Users\Jawska\Videos\21 Jump Street 2012 R5 NEW LiNE XViD - INSPiRAL\21 Jump Street 2012 R5 NEW LiNE XViD - INSPiRAL.avi
Format : AVI
File size : 1.38 GiB
Duration : 1h 45mn
Overall bit rate : 1 874 Kbps
Writing library : VirtualDub build 32842/release
Video
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 45mn
Bit rate : 1 736 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.317
Stream size : 1.28 GiB (93%)
Writing library : XviD 64
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 45mn
Bit rate : 128 Kbps
Stream size : 96.6 MiB (7%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Yeah, I noticed that too, Hack Of Avi. I don't know what that means. Maybe someone else does. However, you don't want it anyway because the person making it didn't know what he was doing. It's a 2:1 ratio (640x320) and the film is really 2.35:1. Either someone cut off the sides or (more likely) stretched it so people are too tall and thin looking.
Other than that it's a fairly standard DivX AVI (and not something out of the ordinary, as I was suspecting). However, the title of it says it's XviD. My suggestion is to check the fourCC name and change it to div5 or DX50 (if those are among the choices) if it says XviD. Use the Avi FourCC Code Changer.Last edited by manono; 5th Dec 2012 at 22:47.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 9Last Post: 3rd May 2013, 13:28 -
AVCHD format (MTS file) player
By teroer in forum Newbie / General discussionsReplies: 45Last Post: 16th Dec 2011, 01:36 -
from ATI File Player to .mpg (or any format that fits WMM)
By croarta in forum Video ConversionReplies: 2Last Post: 22nd Dec 2010, 10:10 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 08:53 -
How to convert .TS file to a format recognisable by an ordinary DVD Player?
By comag in forum Video ConversionReplies: 18Last Post: 12th Jan 2008, 10:10
