Hi, several days i have trouble to convert video from h264 codecs, x264 encoder and mp4 container to msmpeg4v2 codec and mp4 container.
Can someone help me with this task?
Thanks.
Something like
orffmpeg -i input.mp4 -vcodec msmpeg4v2 -acodec copy -qscale 20 output.mp4
http://kenta.blogspot.se/2011/11/rgtqevpm-ffmpeg-to-msmpeg4v2.html -
I was try with this and i got this error:
File 'output.mp4' already exists. Overwrite ? [y/N] y
w:720 h:576 pixfmt:yuv420p tb:1/1000000 sar:12/11 sws_param:
[mp4 @ 0x62b9a0] track 0: could not find tag, codec not currently supported in container
Output #0, mp4, to 'output.mp4':
Metadata:
encoder : Lavf53.32.100
Stream #0:0: Video: msmpeg4v2, yuv420p, 720x576 [SAR 12:11 DAR 15:11], q=2-31, 200 kb/s, 90k tbn, 50 tbc
Stream #0:1: Audio: mp2 (i[0][0][0] / 0x0069), 48000 Hz, stereo, 192 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> msmpeg4v2)
Stream #0:2 -> #0:1 (copy)
Could not write header for output file #0 (incorrect codec parameters ?)
It can be possible to convert like this only if output is avi -
msmpeg4v2 is probably not supported in mp4 then.
Does it work if you try avi? -
Yes it work with avi, but i have one problem. Android devices does not play Avi files, only mp4
But android devices support h264 ? Maybe not all profiles/presets then.
Well i have android device 2.1, it can able to play base media / version 2, codec id mp42. Linux can encode profil base media, codec id isom
Convert MKV with .ass subs to mp4 with ffmpeg
By bearnado in forum Video ConversionReplies: 2Last Post: 1st Mar 2012, 02:21 -
FFmpeg error trying to convert audio in mp4
By Thunderhead2772 in forum Video ConversionReplies: 3Last Post: 6th Feb 2012, 23:36 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 19:41 -
FFmpeg Audio Codecs
By Klagar in forum AudioReplies: 10Last Post: 11th Nov 2010, 11:15
