    I'm trying to encode some audio on Ubuntu 12.04 Linux. I need to use libfaac (using version 1.28) to encode and I want to encode at a very low bitrate - the total including transport stream overhead must be below 64kbps.
    The input audio is: PCM, 48kHz, 2 channel, s16, 1536 kb/s
    Using the faac command-line tool, I get the output below, encoding 5 minutes of audio - so there's plenty of time for the bitrate to average out. I cannot get it to go below 64kbps, or above 165kbps for that matter. I have tried setting some of the other parameters, but to no avail. When I set the bitrate > 64, it works fine.
    $ ./faac -b 40 -w -o /tmp/yellow-audio-40k.mp4 /tmp/yellow-audio.wavFreeware Advanced Audio Coder
    FAAC 1.28
    Average bitrate: 64 kbps
    Quantization quality: 100
    Bandwidth: 5442 Hz
    Object type: Low Complexity(MPEG-4) + M/S
    Container format: MPEG-4 File Format (MP4)
    Encoding /tmp/yellow-audio.wav to /tmp/yellow-audio-40k.mp4
    frame | bitrate | elapsed/estim | play/CPU | ETA
    14063/14063 (100%)| 64.2 | 10.7/10.7 | 27.91x | 0.0
    $ mediainfo /tmp/yellow-audio-40k.mp4
    General
    Complete name : /tmp/yellow-audio-40k.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 2.35 MiB
    Duration : 5mn 0s
    Overall bit rate : 65.7 Kbps
    Encoded date : UTC 2012-12-05 00:03:38
    Tagged date : UTC 2012-12-05 00:03:49
    Writing application : FAAC 1.28
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 5mn 0s
    Bit rate mode : Variable
    Bit rate : 64.2 Kbps
    Maximum bit rate : 73.7 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 2.30 MiB (98%)
    Language : English
  2. inactive El Heggunte's Avatar
    Hmmm, why do you "have to" use faac only?
    Can't you use NeroAacEnc under WINE for example?
    Keep in mind that lower bitrates sound better/acceptable only with the High-Efficiency mode
    (read: Spectral Band Replication)
    I tried it with ffmpeg libvo-aacenc instead of libfaac (on windows) and it was able to reach the targets of 40kb/s, 48kb/s AAC . Some AAC encoders have unavailable bitrate options, and only specific numbers work (e.g. you might not be able to use 45kb/s)
    Another option might be to pipe ffmpeg into another aac encoder like neroaac
    see this thread:
    http://forum.videohelp.com/threads/322328-libfaac-encoding-with-ffmpeg
    bat99 is on linux , so either option should work for you on linux
    I agree with El Heggunte,
    And even to my non-audiophile ears , there is a world of difference between something like neroaac HE-AAC and libfaac in terms of quality, especially at low bitrates
    i'm working on an application which already is using libfaac as it's chosen aac encoding library. It would be a fair bit of work to switch libraries. I do wish libfaac supported HE-AAC... maybe I could use the built-in ffmpeg aac encoder
    Finally figured it out. In order to encode at bitrates < 64kbps, you must also set the bandwidth:
    -c <freq> Set the bandwidth in Hz. (default=automatic)
    the bitrate and bandwidth parameters work in tandem to generate an output bitrate. It's automatically set to
    about 1/2 of the sample rate, but you must set it much lower (in my case <5000) to allow libfaac to
    encode at 40kbps or similar.
  7. Member bat999's Avatar
    Originally Posted by lightdee View Post
    Finally figured it out... you must also set the bandwidth
    ...you must set it much lower (in my case <5000) to allow libfaac to
    Yes, that's done the job.
    I suppose this low bandwidth is OK for speech.
    @ubuntu:~$ faac -b 40 -c 4000 -o foo.m4a foo.wav
    FAAC 1.28
    Average bitrate: 40 kbps
    Bandwidth: 4000 Hz
    Encoding foo.wav to foo.m4a
     1297/1297  (100%)|   42.1  |    2.1/2.1    |   14.68x | 0.0
