1080p is a rather common thing to find in a $100-$200 capture card these days. For me, the top of the line in this range is either the Black Magic Intensity Pro or the Avermedia Live Gamer HD...but there's a problem. These cards only capture at 30fps (technically BMIP will do 1080i60, but not p, so it's really only the same 30fps that Avermedia will record at). I'm looking for a capture device that will record HDMI at 1080p60. Most cards that I find are bank-breakers, including the top end of the Black Magic lineup (the two 'DeckLink extreme' models) and various other cards, but they all cost around $1k and I'm not sure about spending that kind of money without recommendations from others. What are your thoughts? Do you know of any 1080p60 cards out there that are worth their price?
Thanks!
Results 1 to 25 of 25
There are a few capture devices in your price range that have a pass-through for 1080p60 and capture 1080p60 as 1080p30, but none whatsoever that have specs listing capture at 1080p60. Since I don't think you are interested in something that captures 1080p60 as 1080p30, I won't bother digging up the links for them.
SKYNET MONSTER XX
The only 1080p@60 I know
Look here: http://www.sknet-web.co.jp/english/m...ification.html
Claudio -
Yeah I've seen a couple with pass-through at p60 but none that record. Thanks for the help guys, I guess you gotta dig deep in your pockets for full 1080p60 capturing :-p
Thanks for the capture card link, that one isn't terribly priced at about 600 USD, but there's no pass-through at all on that card, something I was hoping for. Looks like I'm looking for a card that just doesn't exist in a low price range, good to know
I'll probably set my sights on the Black Magic DeckLink Extreme cards, or are there any other recommendations for top-end capture cards?
HDMI to HD-SDI converter + HD-SDI recording card (or even 3Gbps SDI is required for 1080p60)
If you wanted to try the MonsterX card, you could use a powered HDMI splitter to get around the lack of a pass-through. I have not heard that a powered HDMI splitter introduces any delay, and they are not terribly expensive.
Here is an example: http://www.monoprice.com/products/pr...seq=1&format=2 -
I wanna blow the bank on that MonsterXX, but I don't know where to buy one. Anyone know a place that ships to North America?
Prices below assume you are able to get rock-bottom best deals on everything.
http://www.adorama.com/VDBMBCH2S.html ($280)
+ http://www.bhphotovideo.com/c/produc...ckLink_4K.html ($565 estimated)
+ HDMI splitter ($20)
+ HDMI cables ($10)
+ SDI cable ($20)
= $895 (free shipping at least!)
+ HDCP stripper ($65 estimated)
= $960
IF NOT IN USA: shipping ($30 estimated) + import costs ($5 + 5%, for example)
= $1043 estimated
That is the only Blackmagic card that supports 1080p60, and it isn't even out yet! The capture card supports 16 channels of audio, but the HDMI to HD-SDI converter can only support 2 channels. Such a waste. The converter also only does YUV 4:2:2 (YUV 4:4:4 up to 1080p29.97).
So even spending that crazy amount of money and chaining a bunch of shit together you've still got compromises being made. The MonsterXX looks reasonable by comparison.
Alternatives:
http://www.datapath.co.uk/products/v.../visionrgb-e1s ($900-1000) (YUV 4:2:2 and RGB 8:8:8, no audio at all)
http://www.datapath.co.uk/products/v...cards/visionav ($1500) (YUV 4:2:2 and RGB 8:8:8, audio, analog capture as a bonus)Last edited by vaporeon800; 4th Dec 2012 at 14:35.
Eww, analog! Death to analog, pandy.
I disagree that overall HD capture is expensive. At the low end we have the AVerMedia HD DVR which thanks to two different exploits can capture HDCP-encrypted video in either uncompressed, lossless, or lossy. Only downside is it converts everything to 4:2:2.
Then the next step up, same manufacturer, we get 1080p59.94 and 1080p60 input, but both are decimated to 1080p30.00 (this is bad with the common 59.94 input, since it means jerkiness is inherently going to happen every 33.33 seconds). I would like to know if the other devices that decimate to "1080p30" share this flaw.
AVerMedia HD DVR: $93 (YUV 4:2:2 autoconversion, 720p60 and 1080i60 max)
AVerMedia Game Broadcaster HD: $140 (YUV 4:2:2 autoconversion, 1080p60 max input but decimated to 1080p30.0)
High affordable. It's only when we get into the next step up, the cream of the crop, the golden jewel: real 1080p60 capture, that we jump up big time in price.
Of course if you were someone who decided any capture card that doesn't do RGB 8:8:8 capture isn't worth your time and you will only accept 100% mathematically exact input-to-file creation, then I would agreed that any HD capturing would be expensive. -
Why?
IMHO analog provide quite comparable quality to digital - sometimes from subjective point of view better.
Yes, consumer format capture cards are affordable priced but we talking about 1080p60 solution which is not very popular even in studios because there is no consumer market with general support for 1080p60, amount of video sources is also very limited (mostly synthetic generation, some cameras)
There is very limited amount of video sources that produce real, usable 1080p60 thus no market for capture devices especially that most 1080p60 sources provide recorded content in digital way - easy to transfer or to copy.
No consumer 1080p60 video sources no market for 1080p60 capture devices. This rule is quite simple.
Perhaps HDMI anyway is not a good interface - there is better alternative as DP for example http://www.unigraf.fi/products/video...g/ufg-06-nopeaLast edited by pandy; 6th Dec 2012 at 04:36.
Not quite. All a/v sources start in life as analog. Conversion to digital is a storage and digital duplication process, and not an especially accurate one. And in the final analysis, all a/v is reconverted from digital to analog for playback. Ever heard of a DAC? So until we humans have another 35 million years of evolution to go through before physically developing "digital" sensory organs, your eyes and ears and nervous response system are 100% analog. They can't do a thing with 0's and 1's. That PC monitor, HDTV, speakers....they're all digital-to-analog devices in the end.
Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
For all practical purposes it is "death to analog video connections", whether one likes it or not. Since most consumers as well as content providers demand HDMI, and manufacturers are happy to cut costs, the fate of analog video connections is sealed at this point.
As far as the makers of PC capture equipment are concerned, it looks like the development of new consumer Mac/PC capture devices for recording TV or digitizing analog tapes has become an afterthought. Most new capture devices I have seen of late have primarily been designed and marketed for video game capture.
The number of posts here at Video Help asking for consumer 1080p60 or 1080p50 HDMI capture devices from video gamers who want to capture 1080p output from PC games and game consoles also point to a stronger demand for that type of capture product. -
Yeah, you're right. I saw it comin', and spent 8 years building and collecting analog hardware old and (fairly) new. The worst of it is LCD, which I find impossible to overcome. The guy who thought of a way to make displays out of those tiny cholesterol beads must have been the greatest con artist of all time. Oh well, maybe OLED will happen...eventually, and some of this will look credible again. Meanwhile, it's work with what you have.
Since you're talking about a personal preference all I can say is that I don't share it, at all.
I have tried 1080p from PS3 over component and the detail was terrible compared to HDMI. Several people have reported the same problem using the AVerMedia Game Capture HD's component input.
Now you might say that I just used bad component cables, and you would be correct, but I can literally buy a $2 HDMI from the local dollar store that provides 100% accurate reproduction of the 1080p signal. So how is analog superior if I have pay more just to get something close to the same thing? (Please do not pipe in here, Sanlyn, unless you can provide factual evidence rather than observations. Thanks.).
Current-generation video game consoles, PC games, and most current consumer camcorders.Yes, consumer format capture cards are affordable priced but we talking about 1080p60 solution which is not very popular even in studios because there is no consumer market with general support for 1080p60, amount of video sources is also very limited (mostly synthetic generation, some cameras)
See above. AVCHD is highly compressed compared to the HDMI output of the same camcorders.There is very limited amount of video sources that produce real, usable 1080p60 thus no market for capture devices especially that most 1080p60 sources provide recorded content in digital way - easy to transfer or to copy. -
Your definition of A/V source must be far more restrictive than mine.
http://en.wikipedia.org/wiki/Galaxy_Game
http://en.wikipedia.org/wiki/Digital_synthesizer
http://en.wikipedia.org/wiki/Timelin...and_television -
This is quite objective claim - normal video range in digital world is 16-235 for Y and 16 - 240 Cx, in DAC they are changed to analog signal with some level - for example 0 - 1V - from this point, with correct reconstruction filter next ADC (in TV) with corresponding antialiasing filter resample such signal - usually with use more levels than in broadcast domain, thanks to small imperfections and noise You can have more than 219 quantization steps for Y and more than 224 quantization steps for Cx signal - if You compare directly digital interface with analog then for example banding is less visible thanks to additional intermediate steps added to signal.
Most current consumer recorders are barely able to record 30 fps - most of them use cheap and slow, small CMOS sensors - they produce plenty of noise - this is physics - show me consumer recorder with cooled sensor, show me affordable priced camera with frame transfer CMOS sensor, large enough to produce comparable signal for fast frame acquisition - 60 - 100fps - such things not exist.
You can't ignore physics.
To conclude:
My point is - people recording game consoles and providing such videos on YT are not particularly big market to start new area of business - currently this is niche market and will remain niche unless Hollywood will start big revolution and movies will be recorded with at least 60fps (which seems to be not very real for next few years). -
Back on topic, I see there is a cheaper Blackmagic device that does 1080p60 without needing the SDI conversion. For some reason this device limits HDMI audio to 2 channels, though!
It's an external box that connects using Thunderbolt. If you don't already have a Thunderbolt computer you would need to add that expense as well:
Wikipedia's list of Thunderbolt-compatible devices
The cheapest route is buying a motherboard and building your own system, hopefully with other parts you already possess.
http://www.bhphotovideo.com/c/produc...o_Express.html ($470)
http://www.amazon.com/Gigabyte-LGA11.../dp/B007R21JX6 ($120)[--or-- http://www.amazon.com/MSI-Intel-Moth.../dp/B009K1PXQ6 ($166)]
+ http://www.amazon.com/Intel-Celeron-.../dp/B0093H8LIY (super-cheap, $39)[--or-- http://www.amazon.com/Intel-i3-2120-.../dp/B004KZDV8E ($117)]
= $629 for the crappiest barebones UltraStudio Express computer system available
+ HDMI cables ($10)
= $659
= $724 -
What's mythical about it? There's a thread dedicated to HDCP strippers where it is shown in video form. I don't link to it publicly.
Found this on eBay:
http://www.ebay.com/itm/Professional...-/251187891457 ($356)
But it's only a PCIe x1 interface. I guess this is only designed for grabbing screenshots, because 200MB/sec isn't enough for a software compression card like this to do 1080p60 at full rate. -
But Why? if there is public discussion then i see no point to refuse point to link - i'm quite curious because such thing like HDCP stripper for 65$ is comparable to unicorn living in your neighborhood...
There are some HDMI capture card with "error" driver with "accidental" HDCP capturing - plenty of tricks however i need to buy real existing HDCP stripper thus i'm searching for myself and knowing this thread i have problem to find HDCP stripper for 65$. Can You help me?
IMHO this card have chance to be capable perform hardware compression (FPGA+large RAM on board).
Always You can try to use something like this http://www.digilentinc.com/Products/...836&Prod=ATLYS some lossless realtime compression should be possible.Last edited by pandy; 11th Dec 2012 at 07:17.
Figured I'd just add to this thread as I'm looking for the cheapest capture card that can record 1080p/60fps videos. So far, the potential ones I've found are:
Adlink HDV62 $975.70
Aja KONA 3G $1,995.00
Aja KONA LHi $1,295.00
BlackMagic DeckLink 4K Extreme $945.25
DataPath VisionAV $1,020.00
DataPath VisionDVI-DL $1,464.00
DataPath VisionRGB-E1S $705.00
DataPath VisionRGB-E2S $1,985.00
DataPath VisionSD4+1s
Epiphan DVI2PCIe $999.95
iEi HDC-301 $369.00
iEi HDC-301E $369.00
iEi HDC-302E $708.50
iEi HDC-304E $1,142.90
iEi HDC-401E $447.00
Viewcast Osprey 920e $1,345.99
Skynet MonsterXX
Sinetrones VDB-510N1
Timeleak HD100C
Unfortunately, as I'm looking for recording uncompressed 1080p/60fps so those sub $500 iEi ones don't work for me. Links for any other 1080p/60fps video cards would be greatly helpful.Last edited by ScardyBob; 1st May 2013 at 11:59.
This one's about $350....let us know how you get on...
http://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=/search%3Fq%3DMi...cJadQ90Tk8ZlEg
1080p60 8 audio channels HDMI capture card
By stereoactivo in forum CapturingReplies: 7Last Post: 6th Mar 2013, 03:24 -
VHS Capture Card - Updated Recommendations?
By Hessian in forum Newbie / General discussionsReplies: 3Last Post: 16th Oct 2012, 08:49 -
Capture card recommendations?
By dougieex0x in forum CapturingReplies: 1Last Post: 9th Jan 2011, 23:45 -
New capture card recommendations with some specfic features?
By justin81 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2009, 12:00 -
HD Capture - Any way to convert from 1080p60 to 1080p24?
By Corvius in forum CapturingReplies: 4Last Post: 8th Nov 2008, 06:16
