Hello All,
I have had this unit for approximately 6 years. Even though it has received a number of negative reviews, it has served me well up until a few weeks ago. I started to record a football game in SP mode. I use Verbatim DVD+R discs. As I approached the 2 hour mark, I stopped recording, finalized the disc, and inserted another. The unit asked me to initialize the disc, which I did. After a few seconds, the unit responded "Could not initialize disc. Error detection." I tried several more, all with the same result. I had some cheap memorex discs, same thing. I looked up possible issues with the unit, but couldn't find a fix. I let the unit sit for a few days, and tried to record again - It worked. It initialized the disc, and recorded. When I tried a second disc, I received the error detection message again. I tried cleaning the lens with no change. Has anybody tried to change the drive out? I've done a few drive changes with some Lite-On units, but this unit only has 1 flat ribbon wire connection - the Lite-On units have IDE connections. unless someone can give me direction on making a connection to the Flat connector? Thanks.
A small effort of Manners goes a long way down the road
No harm in asking. Most DVD recorders use non-standard connectors to the burner and you'd have to replace the burner with the exact same model. Those old models are likely not made any more and if you can find them at all, you roll the dice that the used one you bought on Ebay will last more than a few months. If others know anything specific about your situation, they'll post.
Ancient machine - PLEASE HELP - Samsung DVD-VR330 won't play DVDs any more
By scarletmummy in forum RestorationReplies: 6Last Post: 5th Feb 2012, 06:58 -
Samsung VR330 ejected disc during finalizing - cannot be played.
By ecc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Feb 2009, 13:07 -
VHS to DVDRW recording with Samsung VR330
By ecc in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jan 2009, 15:53 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
samsung dvd-vr330
By etanant in forum DVD & Blu-ray RecordersReplies: 0Last Post: 19th Dec 2007, 03:57
