  1. Hi i am keen to make my tuners share out on the internet and i have stumbled across NEWA.
    http://www.gbpvr.com/nwiki/pmwiki.php?n=Manual.NEWA
    Now i tried fiddling around with it and i have a total of 3 sources over 2 tv cards on my PC namely
    1. DVB-T off antenna
    2. Analog TV off antenna
    3. S-Video from set top box
    Why is it i can only see DVB-T channels and not the others
    Have you successfully used NPVR for analog sources before trying NEWA, or is this the first time you tried NPVR?
    The reason why I ask is that, from what I recall from trying NPVR last year, only digital tuners are supported using the standard NPVR set up. An analog tuner requires a special set up procedure, utilizing some bits and pieces of software to be obtained from Hauppauge. I don't recall what needs to be done for analog capture.
  3. Yes i am running 2 cards with 3 sources as stated above for a while now under NPVR but i am only now starting to explore NEWA - ya i had to manually add the analog tuner
    If your problem isn't that NPVR has not been set up for the analog sources, I can only offer one other suggestion. I don't know NEWA, but maybe it is not designed to work with analog tuners or analog capture. Have you tried asking your question at the NPVR user forum?
  5. For some reason i can't register there and emailing the admin yielded no results
