i! Please please help me, I want to play a subtitle on my MKV movie files from my USB to be played on PS3 but nothing seems to work... I have tried muxing subttiles with TSMUXER, MKV2VOB, MKVtool, MKVTOOLNIXetc but everytime I do it, there is still no subtitle options on the movie I played, I also tried Subler to convert it to MP4 and pressd the hard coded sub, still no subtitles... I've been reading and readin for almost 2 weeks now and still nothing works... Please please help me... it will be highly appreciated.
NOTE: I want to watch it with the same quality as it is. I've tried and read about hard coding it tho, it takes too much time like hours of encoding also it could hurt the video quality, maybe there are other ways with shorter encoding time? thank you so much!
Results 1 to 15 of 15
What format are the subtitles in the original MKV? If you're not sure, run the MKV through a utility like VideoSpec or iMediaHUD, which will give you more information about the MKV.
I don't think the PS3 really has that many options when it comes to switchable subs, but I could be wrong. MP4s certainly only support a smaller amount of text-based subtitles (such as SRT and one or two other simple subtitle formats).
Hard-coding the subtitles can be generally as fast as any other video re-encoding done on your system. Of course, any re-encoding will mean a drop in quality; whether or not that's significant will depend upon your settings and how the end result looks to you.
You may be able to use Handbrake to generate an MP4 with hardsubs for the PS3, though. I'm not at a system with it installed, but I think it should have a PS3 preset, so you can always try that and see if the quality of the encoding is acceptable for you.If cameras add ten pounds, why would people want to eat them? -
see, it wont et me add my .ssa file on it.. only srt... am i missing something?
yes it is mac... ~_~ im really getting frustrating about this... and yes i wil try to mux the subtitles first into the mkv then put it in hand break... and then tick the burned in subtitle? or the forced one?
You should tick Burned In. You must have something similar to the drop-down box shown in my previous post on a mac.
PS3 is picky when it comes to subs. One way might be to use PS Media Server which is free.
VIDEOBURGER, I tried to do what u said, I mud the .SSA subtitles firt with my MKV movie and then put it in hand break, there now I saw the .SSA subtitles ticked burned in, then after 4 hrs after encoding, there's still no subtitles encoded on the file... =(,... it's getting frustrating,... I ve tried almost everything...=(
HANDYGUY, I know about that, but PS3 media server can be really slow and lag-y when it comes to HD movie files escpecially if you are just using wifi,..=( please help me with this..=(
I can see why you get frustrated so here's a couple of things.
First at the top of the screen in Handbrake where it says Source you can select Chapters. In the drop-down you may also select a time interval so try to select a couple of minutes for test so you don't have to waste 4 hrs.
Second you may find this http://www.youtube.com/watch?v=XHpH6jbEF4o from utube helpful (the first I could find - perhaps there are better ones)
Thirdly if you can't suceed with Handbrake you might consider alternatives like MediaCoder (Multiplatform). It has a Device Edition http://www.mediacoderhq.com/device/psp.htm for PSP and can use your SRT file directly. -
Thanks Videoburger, I'll try this very soon and get back at you about it... please dont give up on me...~_~ lol thank u so much!
MKV to whatever files that the PS3 plays WITH subtitles WITHOUT Transcoding
By Abba91 in forum Video ConversionReplies: 36Last Post: 29th Apr 2012, 12:44 -
play mkv files on Bd-5100 with subtitles
By Mowdy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Feb 2012, 06:36 -
Converted MKV Doubles in Duration PS3
By diesel.1 in forum Newbie / General discussionsReplies: 0Last Post: 7th Dec 2010, 04:14 -
How can I play mp4 files with subtitles on PS3?
By furtem in forum SubtitleReplies: 8Last Post: 24th Jan 2010, 14:03 -
Can a PS3 play mkv x264 files?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 08:28
