Can I use Handbrake to convert a 1080p video clip to 1080i? If so do I go to video filters to do it? Also, my original video is Varible bit rate, should I keep it Variable or do Constant?
James
Results 1 to 22 of 22
Or, can someone please tell me how to convert my 1080p 59fps video files that I just put into Multiavchd, into 1080i video files. Then I plan on using imgburn to burn them onto a BD-R and play on my PS3. The whole reason is that I want another place to store these videos and make it easy for my wife to watch them. I could just leave it as 1080p 59fps but am worried about some stuttering with the video due to PS3 POSSIBLE incapability of playing 1080p 59fps files burnred on a BD-R. I already know it can play 1080i 59fps files burned onto a BD-R without a hitch as I have already done this.
If it were me, rather than worrying about what Sony might/might not do in the future to the PS3, and wasting my time and resources trying to combat what might/might not happen, the simplest solution would be to buy a proper Blu-Ray disk player that does not enforce Cinavia DRM/watermarking. This is a good time of the year to do that.
What is Cinavia DRM/watermarking? I am looking for a Blu-ray player that simply plays my 1920x1080p 59fps video, either from a usb or from a bd-r. Right now, my current PS3 only plays a bd-r that is 1080i 59fps or 720p 59fps.
Ok, well I just recently, using multiavchd & imgburn, authored and burned AVCHD 1920x1080p 29fps, .mts video. I authored it and burned it onto a BD-R and it plays FLAWLESSLY on my PS3. I did it 2x in the last week.
James -
I'm pretty sure Handbrake cannot do that natively. You can use an AviSynth script to convert your 1080p60 source to 1080i30, then encode that with Handbrake by manually enabling interlaced encoding in the codec.
http://forum.videohelp.com/threads/344902-Detelecine-decomb-issues?p=2151515&viewfull=1#post2151515
Code:ffVideoSource("filename.ext") #60p AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave() # 30i, TFF -
h.264 has advanced interlace encoding where parts of the frame can be encoded interlaced, parts progressive, MBAFF (also PAFF where entire frames can be progressive or interlaced). That gives better quality and compression for most material.
But if you encoded your 60p video simply by using the tff flag in Handbrake you have 120 fields per second video. You need to remove half the field before encoding to get 60 fields per second (30i).
To use AviSynth you create a text script with the extension AVS. Paste in the script I gave and save it. Then open that AVS file in an editor as if it was a video file. I thought Handbrake would accept AviSynth scripts but I just tried it and it didn't work. You'll have to use some other encoder. Maybe Xvid4PSP or MeGUI. I use the x264 CLI encoder. -
If I don't remove half the field before encoding, will I have (60i)? If so, I am fine with that, cause my goal is to create 1920x1080i 59fps to author/burn onto a bd-r and then play on my ps3.But if you encoded your 60p video simply by using the tff flag in Handbrake you have 120 fields per second video. You need to remove half the field before encoding to get 60 fields per second (30i).
Back to the avisynth thing: I see your script:
ButffVideoSource("filename.ext") #60p AssumeTFF() SeparateFields() SelectEvery(4,0,3) Weave() # 30i, TFF
WHERE am I supposed to paste this exactly? I have Xvid4PSP. Ok I see, in the CLI part of the custom video encoding. They also have a Fake interlaced option. I wonder what this is?Last edited by jbitakis; 27th Nov 2012 at 01:04.
Create a new text file with the extension ".avs", for example "video.avs" and paste those lines there. Make sure it's not "video.avs.txt", depending on your settings Windows might hide the extension. That file will now work as an .avi file would (with any editor/encoder that recognizes avisynth).
No. What's happened is that marketing has started calling 30i (30 frames per second, two fields per frame) 60i simply because they think bigger numbers sound better. This is to trick purchasers into thinking their 60i camera is better than the competitor's 30i camera. Using that definition, what you have is 120i (60 frames per second, 2 fields per frame). Your PS3 won't play it, just like it doesn't play your 1080p60 videos.
ok now i understand that 60i is pretty much 30i. just mkg. gimmicks. so how do remove half the field?
so the finished product would be 1280x720p 59fps which should look as good as 1080i 30fps?
How do I convert 1080p to 1080i?
By jbitakis in forum Video ConversionReplies: 1Last Post: 18th Nov 2012, 04:38 -
What is better video: 1080p 29fps or 1080i 59fps?
By jbitakis in forum Video ConversionReplies: 2Last Post: 16th Nov 2012, 22:33 -
Convert 1080P to 720P using Handbrake !
By augustya in forum Video ConversionReplies: 24Last Post: 11th Oct 2011, 04:53 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
Convert .TS 1080i into .TS 1080p?
By Lanford in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2010, 02:03
