Results 1 to 23 of 23
  1. I have two tv episodes that are about hour long on each of them. So total of 2 hrs to one dvd5.
    They are in mkv file format. And I used avstodvd to convert them over to my dvd.
    The first episode plays nicely. The video is outstanding and the audio is clear and sync'ed.
    But when the first episode plays thru to the 2nd one the video is still outstanding but the audio is broken up and you can hardly hear it. It does sound like its in sync but you just can make out what they are saying. So basically its not clear or understandable.
    Can someone help out a noob? Not sure what I am doing wrong when trying to do two files to dvd.
    What I tried as burning them each to separate dvd's which worked fine both video and audio is clear but I wanted to keep the two episodes together on one disc.
    What am I doing wrong?
  2. Member hech54's Avatar
    Then the only answer is that your source(es) are crap. Buy them on DVD or Blu Ray.
  3. how could it be crap if I burn one episode to a dvd and it sounds fine? burn the second episode to another single dvd and it sounds fine? But burn both episodes together and the second episode has sound problems?
  4. Originally Posted by Boozer View Post
    If you hadn't said the audio is only bad if you burn more than one encode to a DVD I'd probably have lived the remainder of my life certain that's not possible.
    Maybe avstodvd is doing something odd when converting, if the two MKVs contain different types of audio? Have you tried playing the converted files using the PC (from your hard drive) to see if they sound okay? Given they work okay burned to separate DVDs (and I've never used avstodvd myself so I'm guessing) I assume avstodvd converts them separately when you're burning them to individual discs, so maybe use it to convert the two MKVs as though you'll be burning them to individual discs, save the encoded files to your hard drive, and then use something like DVD Shrink to make a single DVD out of the two avstodvd encodes. There might be a better way to go about it, and I am guessing, but I can't think of another reason why the second audio would be bad when burning them both to the same disc.
  5. AVStoDVD Author _MrC_'s Avatar
    @Boozer
    do you still have the 2 titles project log file? Could you post it here?
    Bye
    MrC
    AVStoDVD Homepage
  6. I cant re-do it if I dont. Im not sure where the log file is. Still a noob to all of this. Ill research where to find the log file and to post it.
  7. AVStoDVD Author _MrC_'s Avatar
    Look into the DVD Output Folder you selected in main AVStoDVD page
    Bye
    MrC
    AVStoDVD Homepage
  8. _MrC_ sorry for the late response. I was able to re-do the project today. I tried burning both episodes again today and the first episode is flawless in video and audio. Then the second one is flawless in video but the audio is just broken up and not understandable at all. Again when I burn just one episode to one disc but are flawless in video and audio. I tried selecting the sound @ 192kp and now today @256kp. I burned them to a dvdrw first then I thought maybe it was due to using a rw. So I tired a +r and got the same results. Can you tell me what I am doing wrong in the audio settings or what is wrong????
    Here is the DVD_0 log file on it.
    <11/25/2012 7:50:25 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 2
    DVD Size: 4449/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: Motion Menu
    Output Folder: C:\Documents and Settings\chainsaw\Desktop
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    PAL SpeedUp: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 256
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 18pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: F: ATAPI iHAS424 A ZL1B
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    Save General Settings: 0
    TITLE 1 SOURCE FILES
    Video: C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.mkv
    Info: AVC - 4726 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 43:40 minutes - 62838 frames
    Audio 1: C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.mkv
    Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 43:40 minutes (0 ms delay) - Internal
    [MediaInfoLib - v0.7.59]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.mkv", CacheFolder="C:\DOCUME~1\chainsaw\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.mkv", CacheFolder="C:\DOCUME~1\chainsaw\LOCALS~1\Temp")
    Video = Video.ConvertToYV12()
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.Spline16Resize(720,480)
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 2021.5 MB
    HCenc Parameters: -ini "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_01 _Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.HCenc.ini"
    HCenc ini file:
    *INFILE C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_01_ Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE_1.avs
    *AVSRELOAD
    *OUTFILE C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE.m2v
    *LOGFILE C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_01_ Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 6470
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *PULLDOWN
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <11/25/2012 8:36:46 PM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE.m2v (2021.3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 6469 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 43:40 minutes - 62836 frames
    START AUDIO DEMUXING OPERATIONS (Track 1)
    FFmpeg Parameters: -i "C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E07.720p.HDTV.x264-EVOLVE.mkv" -acodec copy "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_1.ToFix.ac3"
    <11/25/2012 8:37:29 PM>
    END AUDIO DEMUXING OPERATIONS (Track 1)
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_1.ac3 (120 MB)
    OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 43:40 minutes (0 ms delay)
    TITLE 2 SOURCE FILES
    Video: C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv
    Info: AVC - 5053 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 45:01 minutes - 64778 frames
    Audio 1: C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv
    Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 45:01 minutes (0 ms delay) - Internal
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv", CacheFolder="C:\DOCUME~1\chainsaw\LOCALS~1\Temp", FrameRate=23.976, VFR=false)
    Audio = A2DAudioSource("C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv", CacheFolder="C:\DOCUME~1\chainsaw\LOCALS~1\Temp")
    Target Video FileSize: 2084 MB
    HCenc Parameters: -ini "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_02 _Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.HCenc.ini"
    HCenc ini file:
    *INFILE C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_02_ Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.avs
    *AVSRELOAD
    *OUTFILE C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation.m2v
    *LOGFILE C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Title_02_ Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 6470
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *PULLDOWN
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <11/25/2012 9:21:18 PM>
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation.m2v (1951.6 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 6059 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 45:01 minutes - 64776 frames
    FFmpeg Parameters: -i "C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv" -acodec copy "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_1.ToFix.ac3"
    <11/25/2012 9:26:35 PM>
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_1.ac3 (123.7 MB)
    START DVD MENU BUILDING OPERATIONS
    DVD Menu settings:
    Style: 1
    Aspect Ratio: 1
    Titles Format: 1
    Template: Menu in Black
    Max Titles Page: 12
    Enable Play All: 0
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    Thumb Image Source: 0
    Thumb Frame Position: 10%
    HL Frame Format: 0
    HL Selection Color: 9
    HL Play Color: 8
    Menu Video BitRate: 6000 kbps
    Motion Menu Duration: 15 seconds
    Thumb Drop Shadow: 2
    Play All Shadow: 2
    Arrows Shadow: 0
    <11/25/2012 9:27:15 PM>
    END DVD MENU BUILDING OPERATIONS
    Created File (Menu Page 1): C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_MenuPage1.m2v (10.7 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_BatchMux .ini"
    BatchMux ini file:
    -d "C:\Documents and Settings\chainsaw\Desktop\DVD_0\VIDEO_TS"
    -mxp "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_MuxMan.m xp"
    -l "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_MuxMan.l og"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Palette. txt"
    -v "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE.m2v"
    -vidmode LB
    -a1 "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_1.ac3"
    -a1lang en
    -cellfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_Chapters.txt"
    -progfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_Chapters.txt"
    -chapfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_01_Sons.of.Anarchy.S05E07.720p. HDTV.x264-EVOLVE_Chapters.txt"
    -SEG2v "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation.m2v"
    -SEG2vidmode LB
    -SEG2a1 "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_1.ac3"
    -SEG2a1lang en
    -SEG2cellfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -SEG2progfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -SEG2chapfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Title_02_Sons.of.Anarchy.S05E08.720p. HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -SEG3v "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_MenuPage1.m2v"
    -SEG3vidmode LB
    -SEG3s1 "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Menu.sst"
    -SEG3s1dmode WIDE_LB
    -SEG3hlmnu "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_MenuPage 1_Buttons.mnu"
    -SEG3hlcsm "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Highligh tScheme.csm
    -hcn "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_BatchMux .hcn"
    <11/25/2012 9:31:16 PM>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4307.8 MB
    vs Estimated Size: 4449 MB -> 3.2% undersize
    vs Assets Size: 4227.3 MB -> OK
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Documents and Settings\chainsaw\Desktop\DVD_0 (4307.8 MB)
    <11/25/2012 9:31:18 PM>
    Log file created by AVStoDVD Release 2.5.1
  9. AVStoDVD Author _MrC_'s Avatar
    It does not make sense to me: the 2 titles have a AC3 dvd compliant audio track, that is retained by AVStoDVD "as it is". No re-encoding at all. From the log file there are no errors.
    If the AC3 audio track of the 2nd title is broken, it should be broken always, on the source file, on a DVD with 1 title, on a DVD with multiple titles.
    The only thing I can suggest you (without understanding what's going on), is to force audio re-encoding: go to 'Edit Title'/'Audio' and toggle off 'Auto Audio Setup' and 'Audio Direct Stream Copy'. Then run again the project.
    Bye
    MrC
    MrC
    AVStoDVD Homepage
  10. Okay much thanks. I will give that a try. Will post results.
    Something I noticed, the "demuxing" for the title 1 audio took 45 seconds, while the second title
    took over 5 minutes. Could be a red herring, but I thought I'd mention it.
  12. Thanks Davexnet, what does that mean or what should I look out for or????
  13. AVStoDVD Author _MrC_'s Avatar
    @davexnet
    you are right, 5+ minutes to demux 120 MB is too much. It could be caused by a bad muxing, but I am surprised that running the same title alone the OP says that the output is fine.
    @Boozer
    could you post the log file of the project with only 'Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv'?
    Bye
    MrC
    AVStoDVD Homepage
  14. Sure thing Ill post that up asap. Thank you for the help.
  15. Hi Here is the log just from the one episode
    <11/28/2012 5:36:13 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Titles number: 1
    DVD Size: 2909/4450 MB (65%)
    DVD Label: DVD
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    Video Resolution: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Burning Drive: F:\
    Save Log file: 1
    AVISYNTH SCRIPT
    Encoding Profile: QuEnc CBR 1-pass
    Target Video FileSize: 2737.9 MB
    QuEnc Parameters: -i "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Sons.of. Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.avs" -o "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
    <11/28/2012 6:08:59 PM>
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.m2v (2737.6 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 44:59 minutes - 64713 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.m2v" -srcfps 23.976 -destfps 29.97 -inplace -tff
    <11/28/2012 6:12:37 PM>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.m2v (2737.6 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 45:01 minutes - 64778 frames
    <11/28/2012 6:12:38 PM>
    FFmpeg Parameters: -i "C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv" -acodec copy "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.ToFix.ac3"
    <11/28/2012 6:18:52 PM>
    START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
    FFmpeg Parameters: -threads 2 -i "C:\Documents and Settings\chainsaw\My Documents\Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv" -y -vn -acodec ac3 -sample_fmt flt -ar 48000 -ab 384k "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.ac3"
    <11/28/2012 6:19:50 PM>
    Created File: C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.ac3 (123.7 MB)
    OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 45:01 minutes (0 ms delay)
    DVD Menu settings:
    Style: 1
    Aspect Ratio: 1
    Titles Format: 1
    Max Titles Page: 12
    Enable Play All: 0
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 8
    Play All Shadow: 2
    Arrows Shadow: 0
    <11/28/2012 6:20:13 PM>
    BatchMux ini file:
    -prio LOW
    -v "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.m2v"
    -vidmode LB
    -a1 "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_1.ac3"
    -a1lang en
    -cellfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -progfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -chapfr "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation_Chapters.txt"
    -SEG2v "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_MenuPage1.m2v"
    -SEG2vidmode LB
    -SEG2s1 "C:\Documents and Settings\chainsaw\My Documents\My Videos\DVD_0_Menu.sst"
    -SEG2s1dmode WIDE_LB
    -SEG2hlmnu "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_MenuPage 1_Buttons.mnu"
    -SEG2hlcsm "C:\DOCUME~1\chainsaw\LOCALS~1\Temp\DVD_0_Highligh tScheme.csm
    <11/28/2012 6:22:52 PM>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 2919.8 MB
    vs Estimated Size: 2909 MB -> 0.4% oversize
    vs Assets Size: 2872 MB -> OK
    Created Folder: C:\Documents and Settings\chainsaw\Desktop\DVD_0 (2919.8 MB)
  16. AVStoDVD Author _MrC_'s Avatar
    There is a difference between the 2 projects (2 titles vs 1 title): the audio demuxing routine has failed and the backup audio encoding has been started:
    That's strange and inexplicable from my side.
    BTW I think that you can fix the issue by forcing audio re-encoding, as suggested some posts before.
    Bye
    MrC
    AVStoDVD Homepage
  17. I will try your suggestions. Ill post my results. Thanks again.
    Oh would you like me to do the episode 7 by itself and post the log file? Just to see what it does or no?
  18. Member
    Regarding Sons.of.Anarchy.S05E08.720p.HDTV.x264-EVOLVE Ablation.mkv, I tried it myself and received
    some kind of error during the demux, so I suspect there is something wrong with the file.
    Here's the screen grab:
    Attached Thumbnails Click image for larger version
  19. AVStoDVD Author _MrC_'s Avatar
    Thanks Dave for the try and report.
    Now the mystery is to understand why one title (that title?) is ok and 2 titles are not.
    Bye
    MrC
    AVStoDVD Homepage
    Does the ac3fix run or get bypassed under certain circumstances ?
    (Is the ac3fix step mentioned in the log at all?)
  21. AVStoDVD Author _MrC_'s Avatar
    The ac3fix step is always performed when a AC3 file is retained.
    Bye
    MrC
    AVStoDVD Homepage
  22. Member
    try converting each file separately to MP4 with the same resolution video bitrates/quality and the same audio settings/encoding
    use high quality settings to get the best conversions to MP4
    then load the two mp4 files into avstodvd to create your DVD
    IF needed, you can reduce file size in this step or with DVD shrink
    i have had lots of trouble MKV files in the past and now i totally ignore them and refuse to have anything to do with them,
    i was never able to link separate MKV files into one dvd with any amount of good success ,something was always wrong
  23. Thanks for the info on the mkv files being problematic. First time I ever used them and wont be a fan of them any longer. Im going to try out both suggestions just havent had time to do it up yet.
