Hi,after installing a lot of tools like virtualdub,avidemux.... i did not make the correct audio track for the video.I have 2 different versions of the same movie but the ntsc version has bad video quality and pal has excellent with polska sound.I want to demux the english audio from the ntsc and mux with pal version but i have audio sync problems that is variable,in the beginning of the movie i dont have sync problems but after a couple of minutes lose sync at variable time.
What i did,i install latest virtualdub 1.demux the vbr mp3 audio from the ntsc movie ,full proccesing mode audio and direct stream video, save as pcm wav with default settings 2.Install winlame and convert it with lame mp3 encoder and standard quality to 128 kbs,44100,stereo,cbr.3Using virtual dub i remove from pal movie the polska audio track,direct stream video and audio with no audio check,save as avi.4.Using virtualdub open the pal video with no sound and add the track from ntsc,direct stream video and audio,audio from other file,i choose the mp3 cbr converted audio from winlame and then usinng video frame rate control choose change so video and audio durations match and save as avi.Here are video-audio specs of two video from mediainfo
This is the pal video with no sound
General
Count : 279
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : AVI: 1.22 GiB, 1h 24mn
Count of video streams : 1
Video_Format_List : MPEG-4 Visual
Video_Format_WithHint_List : MPEG-4 Visual (DivX 5)
Codecs Video : DivX 5
Complete name : C:\Users\Desktop\within the rock samples\Tajna.asteroida.1996.avi
Folder name : C:\Users\Desktop\within the rock samples
File name : Tajna.asteroida.1996
File extension : avi
Format : AVI
Format : AVI
Format/Extensions usually used : avi
Commercial name : AVI
Internet media type : video/vnd.avi
Codec : AVI
Codec : AVI
Codec/Info : Audio Video Interleave
Codec/Extensions usually used : avi
File size : 1306743544
File size : 1.22 GiB
File size : 1 GiB
File size : 1.2 GiB
File size : 1.217 GiB
Duration : 5051040
Duration : 1h 24mn
Duration : 1h 24mn 11s 40ms
Duration : 1h 24mn
Duration : 01:24:11.040
Overall bit rate : 2069663
Overall bit rate : 2 070 Kbps
Stream size : 3071737
Stream size : 2.93 MiB (0%)
Stream size : 3 MiB
Stream size : 2.9 MiB
Stream size : 2.929 MiB
Proportion of this stream : 0.00235
Title : DVD-Rip - DivX 5.1.1 Pro High Quality. Encoded - Shaolin5
Movie name : DVD-Rip - DivX 5.1.1 Pro High Quality. Encoded - Shaolin5
Director : Original Sound !
File creation date : UTC 2012-11-13 13:41:05.486
File creation date (local) : 2012-11-13 15:41:05.486
File last modification date : UTC 2012-11-13 13:47:54.326
File last modification date (local) : 2012-11-13 15:47:54.326
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDub build 32842/release
Video
Count : 248
Kind of stream : Video
Inform : 2 065 Kbps, 704*544 (1.294), at 25.000 fps, MPEG-4 Visual (DivX 5) (Packed bitstream) (BVOP1 / GMC2)
Format : MPEG-4 Visual
Commercial name : MPEG-4 Visual
Format settings : BVOP1 / GMC2
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : 2
Format settings, GMC : 2 warppoints
Format settings, Matrix : Default (H.263)
Internet media type : video/MP4V-ES
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Codec ID/Url : http://mediaarea.net/DX50
Codec : DX50
Codec : DivX 5
Codec/Family : MPEG-4V
Codec/Url : http://www.divx.com
Codec/CC : DX50
Codec settings : BVOP / GMC2 / Packed Bitstream
Codec settings, Packet bitstream : Yes
Codec settings, BVOP : Yes
Codec settings, QPel : No
Codec settings, GMC : 2
Codec settings, GMC : 2 warppoints
Codec settings, Matrix : Default (H.263)
Duration : 5051040
Duration : 1h 24mn
Duration : 1h 24mn
Bit rate : 2064797
Bit rate : 2 065 Kbps
Width : 704
Width : 704 pixels
Height : 544
Height : 544 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.294
Frame rate : 25.000
Frame rate : 25.000 fps
Frame count : 126276
Resolution : 8
Resolution : 8 bits
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.216
Stream size : 1303671807
Stream size : 1.21 GiB (100%)
Stream size : 1 GiB
Stream size : 1.2 GiB
Stream size : 1.214 GiB
Proportion of this stream : 0.99765
Writing library : DivX503b1031p
Writing library : DivX 5.1.1 (Maupiti) (UTC 2003-11-19)
Writing library/Name : DivX
Writing library/Version : 5.1.1 (Maupiti)
Writing library/Date : UTC 2003-11-19
This is the ntsc video with polska sound
General
Count : 279
Inform : AVI: 985 MiB, 1h 27mn
Count of audio streams : 1
Video_Format_WithHint_List : MPEG-4 Visual (XviD)
Codecs Video : XviD
Audio_Format_List : MPEG Audio
Audio_Format_WithHint_List : MPEG Audio (MP3)
Audio codecs : MPEG-1 Audio layer 3
Complete name : C:\Users\Downloads\Video\WITHIN THE ROCK.avi
Folder name : C:\Users\Downloads\Video
File name : WITHIN THE ROCK
Format : AVI
Format : AVI
Interleaved : No
Codec : AVI
Codec : AVI
File size : 1032884932
File size : 985 MiB
File size : 985 MiB
File size : 985 MiB
File size : 985 MiB
File size : 985.0 MiB
Duration : 5270098
Duration : 1h 27mn
Duration : 1h 27mn 50s 98ms
Duration : 1h 27mn
Duration : 01:27:50.098
Overall bit rate : 1567918
Overall bit rate : 1 568 Kbps
Stream size : 8810748
Stream size : 8.40 MiB (1%)
Stream size : 8 MiB
Stream size : 8.4 MiB
Stream size : 8.403 MiB
Proportion of this stream : 0.00853
File creation date : UTC 2012-11-11 19:20:43.523
File creation date (local) : 2012-11-11 21:20:43.523
File last modification date : UTC 2012-11-11 19:59:18.957
File last modification date (local) : 2012-11-11 21:59:18.957
Video
Count : 248
Inform : 1 395 Kbps, 640*480 (4:3), at 29.970 fps, MPEG-4 Visual (XviD) (Advanced Simple@L4)
Format profile : Advanced Simple@L4
Format settings, BVOP : No
Format settings, GMC : 0
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Codec ID/Url : http://mediaarea.net/XVID
Codec : XVID
Codec : XviD
Codec/Info : XviD project
Codec/Url : http://www.xvid.org/Downloads.15.0.html
Codec/CC : XVID
Codec profile : Advanced Simple@L4
Codec settings, Packet bitstream : No
Codec settings, BVOP : No
Codec settings, GMC : 0
Codec settings, GMC : No warppoints
Duration : 5270098
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate : 1394545
Bit rate : 1 395 Kbps
Width : 640
Width : 640 pixels
Height : 480
Height : 480 pixels
Display aspect ratio : 1.333
Display aspect ratio : 4:3
Frame rate : 29.970
Frame rate : 29.970 fps
Frame count : 157945
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Color space : YUV
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Bits/(Pixel*Frame) : 0.151
Delay : 0
Delay : 00:00:00.000
Stream size : 918674282
Stream size : 876 MiB (89%)
Stream size : 876.1 MiB
Proportion of this stream : 0.88943
Writing library : Magic0432
Audio
Count : 217
Kind of stream : Audio
Inform : 160 Kbps, 44.1 KHz, 2 channels, MPEG Audio (MP3) (Version 1) (Layer 3) (Joint stereo / MS Stereo)
Format : MPEG Audio
Commercial name : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Mode : Joint stereo
Mode extension : MS Stereo
Internet media type : audio/mpeg
Codec ID : 55
Codec ID/Hint : MP3
Codec ID/Url : http://www.iis.fraunhofer.de/amm/index.html
Codec : MPA1L3
Codec : MPEG-1 Audio layer 3
Codec/Family : MPEG-1
Codec/Info : MPEG-1 or 2 layer 3
Codec/Url : http://www.iis.fraunhofer.de/amm/index.html
Codec/CC : 55
Codec profile : Joint stereo
Duration : 5269995
Duration : 1h 27mn
Duration : 1h 27mn 49s 995ms
Duration : 1h 27mn
Duration : 01:27:49.995
Bit rate mode : CBR
Bit rate mode : Constant
Bit rate : 160000
Bit rate : 160 Kbps
Channel(s) : 2
Channel(s) : 2 channels
Sampling rate : 44100
Sampling rate : 44.1 KHz
Samples count : 232406780
Delay : 0
Delay, origin : Stream
Delay, origin : Raw stream
Delay relative to video : 0
Video0 delay : 0
Stream size : 105399902
Stream size : 101 MiB (10%)
Stream size : 100.5 MiB
Proportion of this stream : 0.10204
Alignment : Aligned
Alignment : Aligned on interleaves
Interleave, duration : 0.78
Interleave, duration : 26
Interleave, duration : 26 ms (0.78 video frame)
This the final pal video with english audio but bad sync
General
Count : 279
Inform : AVI: 1.30 GiB, 1h 27mn
Complete name : C:\Users\Desktop\Tajna.asteroida.199611111.avi
File name : Tajna.asteroida.199611111
Format : AVI
Format : AVI
Interleaved : Yes
Codec : AVI
Codec : AVI
File size : 1394128342
File size : 1.30 GiB
File size : 1 GiB
File size : 1.3 GiB
File size : 1.298 GiB
Duration : 5270074
Duration : 1h 27mn
Duration : 1h 27mn 50s 74ms
Duration : 1h 27mn
Duration : 01:27:50.074
Overall bit rate : 2116294
Overall bit rate : 2 116 Kbps
Stream size : 6135361
Stream size : 5.85 MiB (0%)
Stream size : 6 MiB
Stream size : 5.9 MiB
Stream size : 5.851 MiB
Proportion of this stream : 0.00440
File creation date : UTC 2012-11-16 02:51:36.607
File creation date (local) : 2012-11-16 04:51:36.607
File last modification date : UTC 2012-11-16 02:52:24.458
File last modification date (local) : 2012-11-16 04:52:24.458
Video
Count : 248
Inform : 1 979 Kbps, 704*544 (1.294), at 23.961 fps, MPEG-4 Visual (DivX 5) (Packed bitstream) (BVOP1 / GMC2)
Codec ID : DX50
Codec : DX50
Codec : DivX 5
Codec/CC : DX50
Duration : 5270074
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate : 1978984
Bit rate : 1 979 Kbps
Width : 704
Width : 704 pixels
Height : 544
Height : 544 pixels
Frame rate : 23.961
Frame rate : 23.961 fps
Resolution : 8
Resolution : 8 bits
Color space : YUV
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Delay : 0
Stream size : 1.21 GiB (94%)
Stream size : 1 GiB
Proportion of this stream : 0.93512
Audio
Count : 217
Inform : 128 Kbps, 44.1 KHz, 2 channels, MPEG Audio (MP3) (Version 1) (Layer 3) (Joint stereo / MS Stereo)
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Codec : MPA1L3
Codec/CC : 55
Duration : 5270074
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate mode : CBR
Bit rate : 128000
Bit rate : 128 Kbps
Channel(s) : 2
Samples count : 232943616
Frame count : 202208
Delay : 0
Video0 delay : 0
Stream size : 84321174
Stream size : 80.4 MiB (6%)
Stream size : 80 MiB
Stream size : 80.41 MiB
Proportion of this stream : 0.06048
Alignment : Split
Alignment : Split accross interleaves
Interleave, duration : 1.00
Interleave, duration : 42
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500
Interleave, preload duration : 500 ms
Writing library : LAME3.98r
Encoding settings : -m j -V 4 -q 3 -lowpass 17 -b 128
You don't know what you're talking about. 'PAL' video is 25fps. Did you slow it down yourself (incorrectly)?
Why not just slow your original 'PAL' AVI to 23.976fps (without reencoding) and add the NTSC audio without reencoding it and see if that works.
They probably still won't synch up though, because your NTSC AVI has about 3+ seconds more video even after matching up the framerates. Maybe it's just a delay if you're lucky. -
No virtualdub does it automatically to match the frame rates.
This the the new pal video,i did what you told me but same result,audio sync in the beginning and then loses audio sync in variable time.Could i upload links for download the two versions of movie for anyone willing to help?
General
Count : 279
Inform : AVI: 1.32 GiB, 1h 27mn
Complete name : C:\Users\Desktop\Tajna.asteroida.1996.avi
Format : AVI
Format : AVI
Interleaved : Yes
Codec : AVI
Codec : AVI
File size : 1414271678
File size : 1.32 GiB
File size : 1 GiB
File size : 1.3 GiB
File size : 1.317 GiB
Duration : 5269939
Duration : 1h 27mn
Duration : 1h 27mn 49s 939ms
Duration : 1h 27mn
Duration : 01:27:49.939
Overall bit rate : 2146927
Overall bit rate : 2 147 Kbps
Stream size : 5269448
Stream size : 5.03 MiB (0%)
Stream size : 5 MiB
Stream size : 5.0 MiB
Stream size : 5.025 MiB
Proportion of this stream : 0.00373
File creation date : UTC 2012-11-16 08:55:29.129
File creation date (local) : 2012-11-16 10:55:29.129
File last modification date : UTC 2012-11-16 08:56:17.130
File last modification date (local) : 2012-11-16 10:56:17.130
Video
Count : 248
Inform : 1 979 Kbps, 704*544 (1.294), at 23.962 fps, MPEG-4 Visual (DivX 5) (Packed bitstream) (BVOP1 / GMC2)
Codec ID : DX50
Codec : DX50
Codec : DivX 5
Codec/CC : DX50
Duration : 5269928
Duration : 1h 27mn
Duration : 1h 27mn 49s 928ms
Duration : 1h 27mn
Duration : 01:27:49.928
Bit rate : 1978932
Width : 704
Width : 704 pixels
Height : 544
Height : 544 pixels
Frame rate : 23.962
Frame rate : 23.962 fps
Frame count : 126278
Resolution : 8
Resolution : 8 bits
Color space : YUV
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Delay : 0
Stream size : 1303603446
Stream size : 1.21 GiB (92%)
Stream size : 1 GiB
Proportion of this stream : 0.92175
Audio
Count : 217
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Codec : MPA1L3
Codec/CC : 55
Duration : 5269939
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate mode : CBR
Bit rate : 160000
Bit rate : 160 Kbps
Channel(s) : 2
Samples count : 232404310
Delay : 0
Video0 delay : 0
Stream size : 105398784
Stream size : 101 MiB (7%)
Proportion of this stream : 0.07453
Alignment : Split
Interleave, duration : 1.38
Interleave, duration : 58
Interleave, duration : 58 ms (1.38 video frame)
Interleave, preload duration : 518
Interleave, preload duration : 518 ms -
compare video length and audio length - both must be the same.
fastest way to do this is counting number of frames and frame rate - divide number of frames by frame rate and it will be your video lenght, for audio similar is number of samples and sample rate - if both lenghts are ok then then it should be no problems with muxing audio track and video track.
btw there are only few frame rates:
24000/1001
24
25
30000/1001
30
(there are few others but those above are most common for SD)
If your frame rate seems to be close but not exactly as listed exactly to (1/number of frames) then you may expect problems - fix header for frame rate then perform, normal muxing. -
No you didn't. I never suggested reencoding the audio. Just demux it. As pandy suggests, compare the audio and video lengths before and after. I never told you to have your video be 23.962fps. What I suggested was, Why not just slow your original 'PAL' AVI to 23.976fps (without reencoding) and add the NTSC audio without reencoding it and see if that works. And you haven't done that at all. You also said:
Could i upload links for download the two versions of movie for anyone willing to help? -
Ok sorry for misunderstanding before,i did exactly your guide and it works like a charm!!!!
here is from mediainfo
General
Count : 279
Inform : AVI (OpenDML): 2.09 GiB, 1h 27mn
Audio_Format_List : PCM
Audio_Format_WithHint_List : PCM
Audio codecs : PCM
Format : AVI
Format : AVI
Format profile : OpenDML
Interleaved : Yes
Codec : AVI
Codec : AVI
File size : 2240736376
File size : 2.09 GiB
File size : 2 GiB
File size : 2.1 GiB
File size : 2.087 GiB
Duration : 5266767
Duration : 1h 27mn
Duration : 1h 27mn 46s 767ms
Duration : 1h 27mn
Duration : 01:27:46.767
Overall bit rate : 3403585
Overall bit rate : 3 404 Kbps
Stream size : 8006913
Stream size : 7.64 MiB (0%)
Stream size : 8 MiB
Stream size : 7.6 MiB
Stream size : 7.636 MiB
Proportion of this stream : 0.00357
File creation date : UTC 2012-11-17 10:33:19.587
File creation date (local) : 2012-11-17 12:33:19.587
File last modification date : UTC 2012-11-17 10:35:23.275
File last modification date (local) : 2012-11-17 12:35:23.275
Video
Count : 248
Inform : 1 980 Kbps, 704*544 (1.294), at 23.976 fps, MPEG-4 Visual (DivX 5) (Packed bitstream) (BVOP1 / GMC2)
Codec ID : DX50
Codec : DX50
Codec : DivX 5
Codec/CC : DX50
Duration : 5266767
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate : 1980223
Bit rate : 1 980 Kbps
Width : 704
Width : 704 pixels
Height : 544
Height : 544 pixels
Frame rate : 23.976
Frame rate : 23.976 fps
Resolution : 8
Resolution : 8 bits
Color space : YUV
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Stream size : 1.21 GiB (58%)
Stream size : 1 GiB
Proportion of this stream : 0.58181
Audio
Count : 217
Inform : 1 411.2 Kbps, 44.1 KHz, 16 bits, 2 channels, PCM (Little / Signed)
Format : PCM
Commercial name : PCM
Format settings : Little / Signed
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Url : http://www.microsoft.com/windows/
Codec : PCM
Codec : PCM
Codec/Family : PCM
Codec/Info : Microsoft PCM
Codec/Url : http://www.microsoft.com/windows/
Codec/CC : 1
Codec settings : Little / Signed
Codec settings, Endianness : Little
Codec settings, Sign : Signed
Duration : 5266767
Duration : 1h 27mn
Duration : 1h 27mn
Bit rate mode : CBR
Bit rate : 1411200
Bit rate : 1 411.2 Kbps
Channel(s) : 2
Samples count : 232264425
Resolution : 16
Resolution : 16 bits
Bit depth : 16
Bit depth : 16 bits
Stream size : 929057656
Stream size : 886 MiB (41%)
Stream size : 886.0 MiB
Proportion of this stream : 0.41462
Thanks again you are god
Can I rip NTSC audio and use right away on a PAL version of the video?
By Bansaw in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2012, 09:04 -
Audio/video out of sync after demux-remux
By CarryNL in forum SubtitleReplies: 0Last Post: 14th Sep 2011, 14:31 -
Quickest way to demux & mux audio tracks to MP4 containers?
By spycam in forum Video ConversionReplies: 3Last Post: 3rd Sep 2011, 01:32 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02
