I'm in real need of some better lighting for filming (mainly) weddings. I currently have a 96 LED F&V light that goes on top of the camera. It's good enough but doesn't really give enough light in a big room. I've been looking at the following 800W lights on Amazon. Good price and seems versatile. But then I was reading somewhere that halogen lights may cause problems with cameras with CMOS sensors, like mine. I use the Sony HXR-MC200E.
I'd really appreciate some views on this please. Thanks for your time.
Results 1 to 17 of 17
Thread: Halogen vs. LED Lights
Some halogen lights do have a high-frequency "whine" which will wreak havoc with the audio recording. Test out whichever ones you choose before buying.
Halogen is usually brighter overall (for the wattage,money) but it can be possible to get more balanced, exacting whites with (good) LEDs.
Scott -
He's probably referring to light flicker (from banding) from the CMOS rolling shutter with partial exposures . You can get it with any type of non continous lighting, including incandescent and halogen. Cheap LED lights with no control mechanisms are a nightmare because they run at a completely different cycle
This depends on several factors: The scan rate of the sensor , the electrical grid (e.g. 50 Hz in the UK), light cycling in relationship to the shutter angle of the camera. If you get a frequency mismatch (or a non evenly divisible multiple), you will get a flicker. e.g. 1/50 or 1/100 with exact 50Hz should be "perfect" .
If you had a CMOS camera with global shutter, it wouldn't be an issue, because you get a full exposure each frame
Some basic background info
http://www.davidsatz.com/aboutflicker_en.html -
And one important thing not mentioned: Halogen lights are hot. Led lights are cool.
They need to be cooled too - issue with LED is that they produce only limited spectrum - typical white LED is made form two colors - yellow and blue, white made from RGB LED is slightly better however CRI for good incandescent lamp is still better than RGB LED (good alternative for halogen are ceramic metal halide lamps - efficient and high CRI).
OK, guys. Thanks for the help. I wasn't aware it was so complex. The high pitched whine might be an issue as I seem to be unable to hear high pitched sounds!!! People often say 'what's that high pitched whine?' and I'd say 'what high pitched whine?'
It's all getting a little too technical for me, so can someone simplify it for me - using the Sony HXR-MC2000E (PAL, Europe) and the F&V LED (on-camera) light I seem to be able to get a decent enough lighting and have not had any banding issues. It's just that in terms of output it's not enough. So I need a better output and a more even light. The F&V light sits on top of my camera and follows the action, so to speak, and so the rest of the shot is darkened (I'm talking about situations such as a dance floor at a wedding reception.
Using this set up maybe I should go for a 3 point lighting set up using 3 higher output LED lights on stands. I'm also looking to do some interviews and stuff where I can use 3 point lighting. It's just that having a small budget and SO many thigs to buy I came across some cheap, but good looking, halogen lights with a dimmable output that looks good. Maybe I should re-phrase the original question to:
"Has anyone had any issues with a CMOS camera and halogen lights?" -
Very good point.
http://www.decoledlight.co.uk/led-spotlights.asp -
http://en.wikipedia.org/wiki/Metal_halide_lamp
METAL HALID LAMPS are considered as the best quality light source for video recording, and they have a very high efficiency too. -
No. Only for lamps that have been designed specifically with even/balanced, broad-spectrum output (that work correctly for both film sensor, digital sensor, and human eye), such as the HMI's.
Standard metal halides such as those seen at sports complexes, street lighting, and car headlights would NOT be good. Peaking at wrong points of the spectrum, uneven throw.
That's why HMI's cost so much - to fix the physics so they ARE good lights.
Scott -
Yeah, that's what I just said: HMIs.
best LED on-camera lights
By laurencewithau in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 2nd Sep 2012, 14:56 -
best lighting incandescent, halogen or fluorescent?
By Electric Rider in forum Newbie / General discussionsReplies: 7Last Post: 31st Oct 2011, 07:20 -
Lights for on the move
By B-Twien Bytes in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2010, 08:28 -
Looking for suggestions for lights
By dolphinstreet in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jan 2010, 21:24 -
Lights-off
By joelson in forum EditingReplies: 1Last Post: 4th Dec 2007, 16:15
