I converted mkv and vob files to avi with second audio stream using avidemux and on the computer it works all right (vlc) but my samsung tv recognises only the first audio stream. is it a problem of encoding or is it simply that samsung accepts only one stream per avi-flie (i.e. no use experimenting further)?
TV media players have a lot of limitations so likely it only supports one audio stream in an AVI file. It's not unusual for AVI support to only be for one audio stream in the file. Perhaps Baldrick's suggestion of MP4 will be better or maybe MKV (if the player supports it) support will be for more than 1 audio stream.
No sound from a PCM audio stream using DVDFab DVD to AVI file.
By loninappleton in forum AudioReplies: 8Last Post: 5th Dec 2011, 04:27 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 08:53 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 10:54 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27
