So MeGUI only allows (?) subs ripped from blu-rays in .SUP format. How do I get these to encode into an AVI file as MeGUI's muxer only allows .SRT Files to be encoded into the video. Help?
This is meant to provide you with further information only and not to discourage you or make you come to the conclusion that your task is impossible.
The muxer probably only allows SRT subtitles to keep things simple and not because SUP is illegal or anything like that in AVI. If you are playing these files on a PC, no problem, but you do need to understand that many playback devices such as streaming media players and DVD/BD players do not play subtitles at all inside of AVI containers. They require the subtitles to be in a separate file with the same name as the movie. So if your movie is MYFILM.AVI, then your subtitles need to named MYFILM.SRT.
It's good to convert to SRT because support for SRT playback is very good on just about everything. However, do note that if you are using a language that does not use the Latin alphabet (ie. Russian, Japanese, Thai, Hebrew, Arabic, Hindi, etc.) that you may have subtitle display issues, even on a PC.
convert avi+srt files to avi with embedded subtitles
By flannob in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 06:35 -
Subtitles while encoding VOB to .AVI?
By aeslis in forum ffmpegX general discussionReplies: 5Last Post: 17th Dec 2009, 04:29 -
How do I join two avi files without re-encoding the whole thing?
By jpate86 in forum Video ConversionReplies: 6Last Post: 10th Jun 2009, 06:35 -
No Subtitles after joining 2 avi files
By kinghlg in forum SubtitleReplies: 10Last Post: 12th Mar 2009, 05:36 -
Re-encoding some AVI files
By jr_dvd_ripper in forum Video ConversionReplies: 1Last Post: 25th Sep 2008, 03:43
