Results 1 to 19 of 19
    Oct 2010
    Brazil
    Hey everyone!
    How do I play a video in full screen and keep the original resolution without stretching it? I mean, to fill black in the background.
    mplayer -fs video.avi (will stretch the video)
    I tried panscan and zoom but didn't work.
    VLC also will do.
    Could not find anything here: http://www.mplayerhq.hu/DOCS/man/en/mplayer.1.html#VIDEO%20FILTERS
    Thanks!
  2. VLC:
    https://forum.videohelp.com/threads/350495-Hauppauge-HD-PVR-SD-Cropping-Info?p=2197438&...=1#post2197438
    Pretty much every player can zoom. In MPCHC select Video Frame -> Touch Window From Inside. In SMPlayer you can zoom with the E key. PotPlayer uses 9 on the keypad.
  3. DECEASED
    Jun 2009
    Heaven
    By means of trial and error, I've found the following command-lines work without glitches for me:
    mplayer -vo gl -fs -vf expand=width:height "video.mp4"
    mplayer -vo gl2 -fs -vf expand=width:height "video.mp4"
    so if your monitor's resolution is, let's say, 1280x800, then width=1280 and height=800
    HTH
    Oct 2010
    Brazil
    still doesn't work. it plays the movie in full screen but stretches it.
    Oct 2010
    Brazil
    with this, it plays in 3x4, but still not the original resolution:
    mplayer -vf expand=:::::1 "video.mp4"
    Mar 2011
    Nova Scotia, Canada
    I don't quite get it here ... is this a learning exercise?
    There are very good mplayer front ends out there. Smplayer for windows and linux, which is what I use. Umplayer for windows, linux and mac. Never tried that one. Smplayer is my default. And it has no problems whatsoever with aspect ratios.
  7. I don't know what you mean by "keep original video resolution". For example, do you want a 640x480 video to play at 640x480 in the middle of a 1920x1080 screen with black borders all around it?
    Oct 2010
    Brazil
    I do use smplayer too.
    There are these videos in low resolution when played in full screen (1920x1080) will stretch too much.
    i just want to play them in the original resolution with a black screen in the background.
  9. So you want your video to play like this when full screen?
  10. DECEASED
    Jun 2009
    Heaven
    Looks like Mplayer (or the build you're using, at least) has problems with certain drivers or video cards.
    Oct 2010
    Brazil
    [Attachment 14566 - Click to enlarge]
    exactly! that's what i'm trying to get.
    How did you do it?
  12. I used MPCHC. VLC can do that too, turn off the Always Fit Window option. I don't know about mplayer. But in smplayer you can hit w multiple times to reduce the picture size.
  13. Banned
    New York, US
    The newest versions of Win Media Player have no respect for aspect ratios. Add inferior playback to begin with, and the suggestion to use something better seems more than reasonable.
  14. The OP isn't using Windows Media Player. He's using mplayer, a linux command line player. Though it's not clear if he's running Linux or Windows.
  15. Banned
    New York, US
    In case the O.P. considers WMP. . . .Most linux users I know are running linux and Windows both. But the O.P. didn't say which...
    Oct 2010
    Brazil
    using windows 7 x64
    not using wmp
  17. Banned
    New York, US
    using windows 7 x64
    not using wmp
    Good decision.
  18. Originally Posted by jagabo View Post
    But in this way you never know if the video is exacly at 100 or 150/200%
    In MPCHC you can easily do, but in smplayer window and video size are not separated
  19. Originally Posted by movmasty View Post
    It tells you the size in the status bar at the bottom.
    Then what's this?
    It works in full screen too:
    Notice the "zoom 0.5" in both images.
