  1. Member danilson's Avatar
    My capture card does not want to catch, error 10 in the installation of video, what does that mean?
    It comes with the screen all black, came after my mother had a plate overload and burned some components, starting hence my capture card does not work anymore, what can I do?
    http://www.wei.cl/images/products/TVDVPIN005g.gif
  2. Member danilson's Avatar
    up
  3. Member johns0's Avatar
    Please do not bump your post so soon,wait at least 2 days.I did a google search and found a few answers.
    Error 10 is device cannot start for one or more reasons ... generally its a hardware fault.
    What ever the original fault was prior to this error you could
    1: uninstall all drivers and software with came with the device, shut the system down
    2: move the device to another slot
    3: Restart and let system detect and load device drivers
    If the device drivers are part of an installer package ignore window driver install and run the package, reboot, windows may repeat device driver request, point to directory where drivers installed to.
    If windows dose not detect device install the device drivers as per normal, usually from the cd which came with the device.
    4: reboot
    5: test, if error 10, card is defective
    If it still shows error 10 it's a done deal it needs to be replaced although that depends if the mother board developed the fault as you question is some what cryptic ( a little hard to understand)
  5. More information needed on "plate overload and burned some components". Sounds like an electrical problem followed by hardware failure, but that's a rough guess.
    Surge Protectors are a good thing to have.
  6. Member themaster1's Avatar
    the pctv... this brings back memories i used to have error code 10 i recall, the best way to cure this is to fully uninstall the drivers and reinstall also you may want to move the card to the 1st pci slot ( the one at the very top next to the pci-e (GC).
  7. Member danilson's Avatar
    I'll explain what happened.
    He wore a motherboard with this PCTV, http://www.wei.cl/images/products/TVDVPIN005g.gif
    But we had a power outage and the motherboard stopped working, I bought another.
    And when I try to install the PCTV pci motherboard new, gave error 10, tried with windows xp and windows 7 and nothing.
    But I see no apparent defect in PCTV, nothing burned her, she can be recognized by windows and install up the audio, but the video does not install.
    If the fact that it is recognized by windows proprio, makes her not be burned, so she is not burned, was wondering how I install my PCTV again.
    My PCTV is a Pinnacle PCTV Pro PCI m1865m (BT848 chipset)
    http://produto.mercadolivre.com.br/MLB-212504359-placa-pci-pinnacle-pctv-stereo-pro-9-_JM
    My Motherboard is a, 775 BIOSTAR G31M DD (purple color)
    she only possesses a PCI slot of red
  8. Member danilson's Avatar
    i think so, the my capture card does not want work, maybe it could be bunrned!
