    Mar 2008
    Oman
    OK so I know it's my fault....I updated a perfectly working system with the latest K-Lite Codec Pack....
    But how do I fix this ? When I start mplayerclassic it tells me ffmpeg.dll failed to load but then proceeds to play the movie. However, my current Vegas video project has been halted in its tracks because it won't show certain vids.
    The vids that don't work are AVI files from my GoPro. When I try to load one in VirtualDub it tells me (several times) that it cannot load ffmpeg.dll, then fails to display the video. File Information shows it is trying to use ffdshow (H264) to decode the video.
    Any ideas ?
    Oct 2005
    666th portal
    remove the crap?
    Mar 2008
    Oman
    Did that. No I no longer have mplayerc (which I like) and Vegas still doesn't load the H264 files.
    Is there a better solution ?
  4. install latest version of ffdshow and make sure you enable the vfw decoder you want to use,..
    This is a perfect example of why I always say uninstalling a codec pack doesn't work. It's already too late -- the system has been hosed. You may need to use DXMan to remove codec entries. It's a huge time-consuming pain in the ass, but there's rarely a better way. I still remember the days when you'd have to simply reformat the whole computer (2000-2003), unless you wanted to manually edit the registry keys.
    http://www.videohelp.com/tools/DXMan
    Thus another person has sadly learned of the damage caused by codec packs.
    Just think: This is ONLY the damage you've noticed so far!
    Mar 2008
    Oman
    Well I just uninstalled KLCP 9.3 and reinstalled it.....and selected ffdshow instead of LAV (which was the default) for H264 and it all works now.
