Results 1 to 16 of 16
    Hi everyone,
    I would like to know if you have the region code for the DVD player Philips DVP 3990. I searched in the website but didn't found it.
    Hope you can help me !
    Thanks a lot,
    BejitaSama
  2. Member hech54's Avatar
    This player was released less than a month ago.
    Thanks hech54, so it means that there is no chance to find it ?
  4. Member hech54's Avatar
    One might show up eventually. If anyone would release a brand new hackable player....I'd bet on Philips.
  5. The procedure for DVP3800 works just fine for this model
    http://www.multi-region.net/philips_dvp3800
    Done it, got it working just fine!
    Attached Thumbnails Click image for larger version
  6. epunk, how did you manage this without the number pad on the remote control. i just purchased one, and the remote does not have a number pad.. thanks for your reply..
  7. Member misterbill's Avatar
    Joe,
    Click on the link in his post. It shows how to do it. No numbers needed.
    Bill
  8. Bill, I tried.. he's done it on a dvp3800.. on my setup menu (preferences) there is no option for region.
  9. Done it !............... The tray had to be open...... and then...
    1. Select SETUP then press OK (via the DVD remote control)
    2. Using the arrow down button highlight PREFERENCE
    3. Press NEXT, PREVIOUS, NEXT, PREVIOUS (the >l, l<, >l, l< buttons in the bottom of the remote control ).
      • Your current region should show on the TV screen
    4. Using the arrow down button select region code 0
    5. Press OK
    6. Press the ‘HOME’ button
  10. Originally Posted by joeseaton View Post
    5. Press OK
    yup, exactly what I had posted originally.. and who said I've done it on a dvp3800? Isnt the picture posted crystal clear enough showing it is a dvp3990?
    Read, my young padawan, read!
    Hi, everybody. after reading your instructions for unlocking a Philips dvp 3990-12, just bought one. Inside, I too, found a remote with no number pad. I manage to get into the preferences menu and scroll down to "version info" which when opened displays the screen you've put up on the forum with the model, file name, version,... region code... etc. HOWEVER, impossible to get the curser to move from the highlighted "ok" button... no matter what button on the remote I push. Any suggestions?
    Is there something else to "unlock" first? Or has Philips devised a means of preventing us to de-zone its DVD player?
    ... not happy, as I was counting on this to replace my dying zoneless Peekton player. Please advise.
    manufactures like philips make changes all the time so the hack might've worked when the player was first
    released. you might have a dvd player with newer firmware so the hack no longer works.
    ok... if I've got a newer firmware version and the hack no longer works, any suggestions, other than sending the dvd player back to the store and getting my money back? Is there a Philips remote control with a number keypad out there that might help me to get into the firmware? or am I just being naive ?
    Thanks for responding.
  14. I doubt if there has been a change on this particular player, as it is no longer manufactured. And, no, you can not find a remote for this with a key pad..
    Philips still makes DVD players that can be made region free, even in the USA where such players are becoming rarer. I don't live in Europe so I don't keep up with what Philips sells there, but I would suggest that you look into a new player that has recent reports here of being able to be made region free. Look at the DVD Players list and look under specific players at the DVD Region Code link to see if there are recent reports that the player was unlocked. And be sure to buy a player with a normal remote control with numbers on it. Hopefully you can find information about the remote controls on the Philips website or by doing a search on Google, Yahoo, etc.
    Thanks guys for the information. The problem has been resolved by joeseaton's kind additions to his prior instructions entered above.
    In fact, the next and previous buttons in his precedent replies is a COMBINATION sequence : buttons to be pressed one after another without stopping. Do NOT expect each button pressed to do something in particular on the version page. Do NOT even go to the version page from the preferences menu. Just type the combination. That is what gets you to the version page where the arrow keys FINALLY work.
    BIG thanks, Joe, for sharing. Hope others who buy this make and model will manage with much less frustration than we had.
