I have several mp3 recordings that have been converted from cassette that sound like the recording is playinig too fast and the voices are a bit squeaky or heilum like. It is not super fast but noticeable and irritating. I would guess the person who did the conversion must have has his cassette player play the tape a bit too fast. I do have audacity. Does it have the ability to slow down the speed of the recording a bit? There are voice recordings (sports broadcasts) and not music if that makes any difference.
Results 1 to 19 of 19
Ok, I loaded the file in Audacity and then moved the bar in the upper right hand corner and adjusted it to 97x. The next setting looked like 93x which seemed too slow but didn't see a setting in between.
IF I settle on the 97x speed setting how do I save the entire recording at that speed? -
File/export but dont use 97,use -5 as i suggested,its a % value and 97 will be way too fast,use the - to make it slower.
You could try the very easy to use software called Transcribe to change pitch/speed. Not free software, though.
http://www.seventhstring.com/xscribe/overview.html -
Set slower playrate and if it suit Your subjective expectations resample to some common sampling frequency.
For Audition this is option Adjust Sample Rate (put something lower than current) if it works, then perform Convert Sample Type to for example 44100 or 48000.
Same operations can be performed by SOX (which i recommend due probably higher overall quality for processing)
sox -r 33333.0 inputfile.wav outputfile.wav rate -v -I 44100.0 -
The 5% sounded good when I clicked the green arrow in the upper right hand corner, but when I used File export it didn't sound like it applied the 5% to the recording. Is there something I need to do before I click file export? I might think I need to do something to tell it to apply it to the entire mp3 file.
As noted in a previous post, on the top menu, click 'Effect' > 'Change speed' and insert a negative number to slow it down.
You will see the length of the stream change if it takes effect.
That button you are using only adjusts the playback speed locally - not the exported audio. -
Ok, I see it now. Thanks.
It works pretty well but I wish there was a longer preview. -
If you speed up the audio the duration will be shorter.
Note that doing any of these kinds of conversions will result in some loss of quality (plus more loss if you re-encode to mp3 or similar lossy codec).
Scott -
The loss in quality greatly depends on these things:
- The richness/complexity/dynamics of the source signal (classical music vs. rock music vs. sound effect vs. voice, etc)
- The algorithm(s) involved in the app doing the sample/tempo/pitch/formant conversion.
- The algorithm & bitrate chosen for the lossy final codec.
- The greatness in the amount of change to the signal (.1% vs. 4% vs. 15% vs. 50%)
Fast mp3 encoders?
By bat999 in forum AudioReplies: 5Last Post: 19th Mar 2011, 17:33 -
Fast encoding on a slow computer
By si4h in forum Newbie / General discussionsReplies: 11Last Post: 5th Aug 2010, 11:09 -
Easy/Fast MPG to DVD Options?
By beckmen in forum Video ConversionReplies: 5Last Post: 25th Feb 2010, 17:41 -
How to convert DVDs to AVI (fast, easy, 90% quality retained)
By guns1inger in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2008, 08:56
