Results 1 to 12 of 12
1) Most animation from DVD will be telecined, not interlaced
2) If in the rare case it was really interlaced, there are better deinterlacers but most of them are CPU heavy, you might not get realtime playback unless you have a faster setup (e.g. you might try QTGMC on one of the faster presets) -
I'm not exactly sure how you would set it up for watching a DVD directly (I'm assuming from disc)
If you enabled ffdshow, it has avisynth box, you could probably use QTGMC there . Or if you wrote an avs script , you could play the .avs back directly . Both these would probably require it to be ripped to HDD first
DVD playback software will IVTC on the fly e.g. powerdvd, windvd -
Dredging this up from the abyss now that I have a new PC, which I hope is sufficient for one of the better DI methods:
i5 4670k
GTX 780
The script would look something like this?
SetMemoryMax(512)
SetMTMode(3)
SetMTMode(2)
YourSource("yourfile") -ffVideoSource?
QTGMC( Preset="Medium" )
SelectEven()
SetMTMode(1)
GetMTMode(false) > 0 ? distributor() : last -
This is about all you need:
Code:SetMtMode(2) WhateverSource() QTGMC(preset="medium") SelectEven()
What would I need to set the source to for DVD playback?
ffVideoSource() Leaving the parenthesis empty?
Also, is there a noticeable quality difference between slow, medium, and fast or faster?Last edited by Prince Valiant; 28th Aug 2013 at 12:29.
You need to specify the source file. You can't leave the function empty. And ffVideoSource would only give you the video, no audio.
A commercial DVD is likely to be encrypted. So you would need to decrypt it first or use a decrypter that works in the background. There are probably several VOB files that you have to concatenate. And QTGMC may not be appropriate for the DVD. You need to analyze the video and handle it accordingly.
Code:SetMtMode(2) v1=FFmpegSource2("D:\VIDEO_TS\VTS_01_1.VOB") v2=FFmpegSource2("D:\VIDEO_TS\VTS_01_2.VOB") v3=FFmpegSource2("D:\VIDEO_TS\VTS_01_3.VOB") QTGMC(v1+v2+v3) SelecteEven()
No, from the sound of it you should have taken pdr's suggestion from nearly a year ago and not deinterlaced at all. IVTC'd, maybe, but not deinterlaced. If you provide a short sample of something you're thinking of deinterlacing better advice can be offered.
My older DVDs are a mix.Last edited by manono; 28th Aug 2013 at 15:21.
VirtualDub Deinterlace Filter yadif vs blend
By kreg in forum CapturingReplies: 1Last Post: 22nd Jul 2011, 12:42 -
Deinterlace and reencode with bdrebuilder+ffdshow+yadif at 60fps
By dinobike in forum Video ConversionReplies: 2Last Post: 30th Aug 2010, 13:59
