I have two types of H.264/MPEG-4 AVC files recorded with both, mobile phones and digital camcorders:
- mp4 files, 1280 x 720 at 30.000 fps
and
- 3gp files, 720 x 480 at 14.925 fps
I know this is terrible quality, but I need to transcode everything to a same bag, either PAL or NTSC SD for editing in Premiere and output a DVD. Is there any specific tool to deal with this kind of files using Avisynth scripts and VirtualDub? Other than using DirectShowSource()? The 3gp files with so little pic/s are what is intriguing me the most. If I open them using DirectShowSource() and save them I get a 30.000 fps speeded up file. And if I open them using FFmpegSource2 I get a 15.399 fps file.
Results 1 to 17 of 17
maybe one of these tools could encode your 3gp to a normal spec lossless avi. never tried but it's worth a shot.
http://www.videohelp.com/tools?convert=3GP%20to%20AVI--
It's probably variable frame rate. You're probably going to have lots of problems using it in a NLE with sync issues. The only way to keep it perfect sync with any file is to use VFR, but NLE's don't work with this type of VFR
You can try to convert to CFR with DirectShowSource("video.3gp" fps=x, convertfps=true)
Where x is the base frame rate (I think it should be 15 in this case) . It will insert duplicates in roughly the correct positions, but if the file has large fluctuations in frame rate, the sync issues will be noticble. Small variable deviations won't be that noticable
A 15 fps converted to CFR file will work fine in a NLE, it will either use blends or duplicates to make up the frame rate of the project. E.g. a 29.97 NTSC project will have duplicates every 2nd frame if you have frame blend off, or blended frames if you have frame blend on
If you have a choice, do the NTSC project instead of PAL, because 25 isn't an even multiple of 15. You're going to have irregular cadence issues with any conversion, or if you use retiming/motion interpolation methods you will have morphing artifacts . Your HD files are also 30FPS, which is more friendly to a NTSC than PAL project , and 99% of PAL DVD players can play NTSC discs.Either PAL or NTSC SD for editing in Premiere and output a DVDLast edited by poisondeathray; 18th Sep 2012 at 21:33.
Thanks aedipuss. I tried Mobile 3GP converter but I got a "Can not find "\Temp\mmctmp*.*"... whatever that means. I figure now I can just use AME and convert but I was curious if this could be achieved using VirtualDub and Avisynth. My favorite tools. But now poisondeathray has come with a very informative reply as always, so I gotta try that. I was under the impression I had to use NSTC instead of PAL but now I know exactly why. Thank you!
I just tried DirectShowSource("video.3gp" fps=15, convertfps=true) and it gives me the Avisynth open failure error. Here's what Mediainfo says about the file (the specs I posted earlier were using GSpot):
General
Complete name : E:\video.3gp
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 84.7 MiB
Duration : 1mn 55s
Overall bit rate : 6 142 Kbps
Law rating : (empty)
Released date : 0
Encoded date : UTC 2012-09-08 02:27:12
Tagged date : UTC 2012-09-12 04:17:02
Classification : (empty)
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 1mn 55s
Bit rate mode : Variable
Bit rate : 6 000 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate mode : Variable
Frame rate : 14.972 fps
Minimum frame rate : 3.650 fps
Maximum frame rate : 15.152 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.160
Stream size : 83.3 MiB (98%)
Language : English
Tagged date : UTC 2012-09-08 02:27:12
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 55s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 1.32 MiB (2%)
Language : English
Tagged date : UTC 2012-09-08 02:27:1Last edited by effes; 18th Sep 2012 at 22:36.
Yes, it's VFRFrame rate mode : Variable
If there are prolonged sections where the framerate drops, you may get sync issues when converting to CFR. It may go in and out of sync in places
You need a splitter. Try lav filtersI just tried DirectShowSource("video.3gp" fps=15, convertfps=true) and it gives me the Avisyth open failure error
http://www.videohelp.com/tools/LAV-Filters
Is the directory path correct ?
DirectShowSource("PATH\video.3gp" fps=15, convertfps=true) -
Sorry there is a typo, it's missing a comma . You don't need to install LAV if it opens without the other part
DirectShowSource("PATH\video.3gp" , fps=15, convertfps=true) -
Why does it get converted to 23.976 ?
If your 2 assets are 30p and 15p, it makes more sense to make a 30p DVD
The 1280x720p30 files can just be dropped on a 16:9 NTSC timeline. You don't need to do anything special before, it will automatically be scaled down if you use default settings
EDIT: ughh I see your edited the post. Ignore this post then -
strange size. par=1, square pixel 720x480. normally 720x480 is 4:3 with a square pixel size of 640x480.Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2--
You may have to interpret the AR in premiere for those files to whatever the correct AR is . Some phones actually use square pixels with those dimensions and the DAR really is 3:2 . You will have a mixed AR project if these aren't really 16:9 (since the HD files are 16:9)
Premiere will drop 1 frame out of 1000 in the HD files (because the framerate is 30.0, not 29.97) . If you want, you can make the 720p videos exactly 30000/1001 fps which is the NTSC framerate by slowing both audio & video using:
FFMPEGSource2("video.mp4", atrack=-1)
AssumeFPS(30000,1001, true)
SSRC(48000)
But it's probably easier just to interpet the file in premiere as 29.97 in the clip bin (this does basically the same thing as AssumeFPS)Last edited by poisondeathray; 18th Sep 2012 at 23:30.
Sorry, I was looking at a previous test file I converted with AME. Audio issues occur though. It's Alvin and the Chipmunks!
So basically, I can just drop both the now converted CFR 15fps files and the 30fps HD files in any 16:9 timeline in Premiere and then output a 30p DVD. But just for the sake of curiosity: if I wanted all footage in 29,97 prior to editing in Premiere (since I am transcoding and doing a few quality enhancements anyway) can I just use Video -> Frame Rate -> 'Change framerate to' in VirtualDub? Or would I be destroying the footage? -
Yes, but you still have to figure out the AR issues with the 3gp files .So basically, I can just drop both the now converted CFR 15fps files and the 30fps HD files in any 16:9 timeline in Premiere and then output a 30p DVD
I'm not sure what vdub's frame rate does (which method it uses, blends or dupes or someting else)But just for the sake of curiosity: if I wanted all footage in 29,97 prior to editing in Premiere (since I am transcoding and doing a few quality enhancements anyway) can I just use Video -> Frame Rate -> 'Change framerate to' in VirtualDub? Or would I be destroying the footage?
I know what avisynth's would do:
The 30.0p footage would be treated with AssumeFPS (both audio & video slowed, but framecount unchanged) . or right clicking in the clip bin and intepreting the footage in premiere does the same thing
The 15p CFR corrected footage could be upsampled to 29.97 by either duplicates, blends, or motion interpolated frames. Each method has pros/cons
ChangeFPS(30000,1001) will give duplicates, ConvertFPS(30000,1001) will give blends, or you can use mvtools2 functions to use motion interpolated frames (mflowfps)
You wouldn't use AssumeFPS on the 15p footage, because it will just play 2x faster (both audio & video will play at 29.97, but since the frame count is the same, it will sound like chipmunks and play 2x faster)
AssumeFPS is fine to use for the 30.0 fps file, because the difference is so tiny, you can't hear the difference between 29.97 and 30. The difference is too large for 15->30fpsLast edited by poisondeathray; 19th Sep 2012 at 00:25.
I notice that when importing the HD footage in PR CS6 it already imports automatically as 29,97 fps instead of 30 and you don't need to reinterpret? I don't know if it's a new feature or not, either way I'm done with the HD footage.
About the 3gp files: I think I'll be fine generating duplicates with ChangeFPS(30000,1001), but how do I know what's the correct AR? Here's a grab:
If it's interpreted as 29.97 already, then you don't have to
You shoot a known circular object straight on (not at an angle). eg. a car tire, or circular clock. Check if it looks too tall or too skinny. If it looks like an oval when viewing at 720x480 it's not square pixelshow do I know what's the correct AR? Here's a grab:
720x480 4:3 in square pixel equivalents would be 640x480. So resize it to that and see if it looks distorted
720x480 16:9 in square pixel equivalents would be 854x480. Same thing with the check
How to open .MP4 files in virtualdub? (i want to sharpen mp4
By fuc847 in forum Video ConversionReplies: 23Last Post: 25th Mar 2013, 12:51 -
Using avisynth with Samsung HD MP4 files
By Wakewatcher in forum Video ConversionReplies: 7Last Post: 1st Mar 2011, 17:56 -
Confusion with DGIndex, AviSynth, VirtualDub and audio files
By fatcharlie in forum Newbie / General discussionsReplies: 10Last Post: 1st Mar 2011, 15:49 -
AviSynth & VirtualDub - Comfortable ways to create avs-files?
By klischee in forum EditingReplies: 7Last Post: 28th Oct 2010, 16:20 -
Convert MP4 and MKV using AVISynth 2.5 and VirtualDub
By DruidCtba in forum Video ConversionReplies: 0Last Post: 7th Nov 2009, 07:51
