    Hi,
    I was wondering if it's possible to update libx264 in ffmpeg to a newer version/revision.
    I'm running 0.11.1 at the moment which uses r2200.
    EDIT: Yes, I'm using the Windows version.
  2. Member bat999's Avatar
    Hi
    It's not possible to update libx264 in FFmpeg unless you compile FFmpeg yourself.
    The latest FFmpeg Windows build from Zeranoe uses "x264 core 125 r2208 d9d2288".
    From here ---> http://ffmpeg.zeranoe.com/builds/
    Edit:- d9d2288 is July 18 2012
    Hi
    Ah thanks. I will try it out
