Hey,
My problem is this...I can capture just video without any problems, but as soon as I try to capture video and audio thru a composite connection I get scratchy audio. No frames are dropped, just the audio is of very poor quality, it does not sound like its skipping or popping tho. Capture resolution or audio bitrate does not make a differance.
Capturing from dvd or an svideo connection is perfect tho...maybe its the composite connection, or maybe a hardware issue...any ideas would be much appreciated.
My system
AMD xp1800+
GF3 ti200 with Video In ( my capture card )
256meg DDR
SB Live! Value
thanks.
Stereo channels:
Are some captures using left hand channel out, and your recording on the right hand channel in? and DVD is Stereo so that will be fine ?
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum CapturingReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum CapturingReplies: 4Last Post: 21st Feb 2011, 05:31 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 03:54 -
You Get dropped frames? That's for you
By themaster1 in forum CapturingReplies: 2Last Post: 6th Dec 2009, 22:21 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum CapturingReplies: 0Last Post: 23rd Aug 2007, 20:59
Statistics
Newest guides
Latest tool updates
New media comments
