Whats the fastest way to encode or mux a mp4 without quality loss to make it stream to Xbox 360?
I have a few mp4 that wont play in Xbox 360 (i used to convert my mkv to wmv hd and it
would take 2-4 hours. I found this guide
http://www.afterdawn.com/guides/archive/convert_mkv_to_mp4_for_xbox_360.cfm
which mux's or wte mkv to mp4 without very tittle quality loss if any in 15 mins
top just amazing. I also used YAMB which works but not on all files (do i have to demux? if so how?)
so just wondering if you y'all know how to take any mp4 and mux/encode without minimal loss of quality but also make it playable/stream to Xbox 360 ?
Results 1 to 9 of 9
Thread: Mux or Encode MP4 to xbox 360
If you're not opposed to transcoding you wouldn't need to convert at all. Just use tversity, playon or ps3mediaserver and stream the original file to the xbox. You won't need to convert the file that way. The streaming program does it for you. Only downside is of course your computer needs to be on to do it. And its best to have it be connected to a wired router (the router itself can be wireless of course but have it be connected to your internet modem and xbox physically not wirelessly). Unless you have a wifi n network router and xbox n receiver and get a strong signal I would not advise streaming video over wifi (at least not hd video - sd video on non n networks should be passable without too much buffering delays).
Also are these files you are reencoding originally h264? If they are you have no need to reencode to wmv. Use something like winff to remux to mp4 without touching the video. Use gspot or mediainfo to identify the codec of the original file. Also would work if the original file is divx or xvid also.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I turned the mp4 into mkv without re-encoding using Mp42Mkvac3 v1.6 and and then used Gotsent which always turns mkv's to stream able mp4's with no sync problems. Also used YAMB and mp4box. All those files (i did 4-5 different encoded) steam on xbox and play on pc but the audio is way out of sync how can i fix this? do u want the media info for the mkv or mp4? or both?
MP4 Issue On Xbox 360 (please Help!)
By Cornholio77 in forum Media Center PC / MediaCentersReplies: 9Last Post: 31st Dec 2011, 23:09 -
Why won't this MP4 work on my Xbox 360?
By Jhay in forum Video StreamingReplies: 2Last Post: 20th Dec 2010, 09:31 -
Can I play this MP4 file on Xbox 360?
By Algamish in forum Media Center PC / MediaCentersReplies: 7Last Post: 26th Jun 2010, 13:34 -
My last hope with .MP4 playback on xbox 360
By kanwar786 in forum Video ConversionReplies: 12Last Post: 18th Feb 2009, 12:05 -
Need something like an xbox 360 to play mp4 on tv
By avalanche165 in forum Newbie / General discussionsReplies: 9Last Post: 15th May 2008, 16:35
. I also used
