    Hi all,
    I love MediaInfo, however there's something that bothers me about the app. In the attached shot of a BD file, you'll see that I underlined a line that displays bitrate info. What I don't care for is the shot of my experimental work. I underlined the same spot, where you'll see that it displays the writing library. I'm not sure I necessarily want people to know what I used.
    Is there a way to strip this metadata? (not sure if that's the proper term for it)
    Thanks,
    Justin - P.S... sorry for the large image sizes.
    ReStream can be used to strip all userdata from MPEG-2 video, but it only works with elementary streams (.m2V or .mpv).
    you might be able to do it with a hex editor
    Thanks. I'll check it out the next time I work on something
    Wow. That takes me back. I haven't used a hex editor since I used to code for MAME.
