Results 1 to 30 of 38
    Feb 2001
    europe
    Anybody know of a program which can record HLS streams?
    (If you don't know what HLS means then please make sure your suggestion is actually relevant)
    Can you play it with VLC? THen can you use its recording function(view->advanced controls and use the record button).
    Feb 2001
    europe
    No, alas not.
    HLS is http live streaming, something Apple thought up to stream video via port 80 (the normal browser port), and essentially you get video in 10 second chunks.
  4. Member bat999's Avatar
    Feb 2008
    Originally Posted by branch View Post
    ... HLS streams?
    Have you a link for such a stream?
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ... HLS streams?
    You'd better rephrase that question to ensure that it is "relevant".
  6. Stream recording expert Bahman's Avatar
    Dec 2011
    Tehran, Iran
    ffmpeg is one of options!
    Feb 2001
    europe
    ... HLS streams?
    Sure: http://hls.twit.tv:1935/flosoft/smil:twitStream.smil/playlist.m3u8
    This link btw is quite legal (if that is what worried the next poster ) - all their mateiral is Creative Commons and free to be shared with the world.
    Feb 2001
    europe
    How? It doesn't work for me?
    Could you supply some commandline arguments?
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    It plays in VLC 2.0.3 and I can record it...
  10. Member bat999's Avatar
    Feb 2008
    And command line...
    For a 30 second clip.
    ffmpeg -i http://hls.twit.tv:1935/flosoft/smil:twitStream.smil/playlist.m3u8 -t 30 -c copy output1.mkv
    vlc http://hls.twit.tv:1935/flosoft/smil:twitStream.smil/playlist.m3u8 --stop-time=30 --sout="#std{access=file,mux=mkv,dst='output2.mkv'}" vlc://quit
    Feb 2001
    europe
    Strange, it doesn't in 2.0.0 - who would have thought the last digit should make a difference.
    In 2.0.3 it does play a little, but then the image freezes though the audio continues.
    I might ask you about that if I can't figure out how to use bat999's examples
    Feb 2001
    europe
    And command line...
    Which version of ffmpeg is that? I'm getting a screen full of error messages and no output file.
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    VLC changelog,
    Changes between 2.0.1 and 2.0.2:
    * Improvements and fixes in HLS support
    The image freezes here too after ~30 seconds...so I guess it doesn't work perfect yet. Try ffmpeg instead.
    Feb 2001
    europe
    I tired this version https://www.videohelp.com/tools/ffmpeg
    And whilst it does output 30 seconds or so, it freezes ever couple of seconds then unfreezes a bit then freezes again etc.
  15. Member bat999's Avatar
    Feb 2008
    Hi
    Maybe different commands needed for Windows FFmpeg.
    90 second sample is attached.
    Using this version with Linux.
    @ubuntu:~$ ffmpeg
    ffmpeg version git-2012-07-26-d5d5e3d Copyright (c) 2000-2012 the FFmpeg developers
    built on Jul 26 2012 14:54:57 with gcc 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4)
    configuration: --enable-gpl --enable-libaacplus --enable-libfaac --enable-libfdk-aac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-nonfree --enable-version3 --enable-x11grab
    Feb 2001
    europe
    Well, my PC version seems to be missing: -enable-libaacplus --enable-libfaac --enable-libfdk-aac --enable-libtheora --enable-nonfree --enable-x11grab
    Feb 2001
    europe
    Ok bat, I found the 2012-07-26 64 bit version for Windows 7.
    And your code example produces a 30 second mkv which looks fine.
    Though the console is still full of spam output like
    [mpegts @ 000000000055f3a0] Invalid timestamps stream=1, pts=1844280000, dts=1844282970, size=1533
    Anyway to disable that?
  18. Member bat999's Avatar
    Feb 2008
    ... Anyway to disable that?
    Hi
    Mine shows all that guff about timestamps too.
    I don't know whether it's a problem, or not.
    Do the FFmpeg downloaded clips play OK for you?
    Is the audio in sync?
    (My weak pc struggles to play 1280x720)
    Feb 2001
    europe
    Hi
    Just seems to be a bit wasteful on resources to do that.
    Seems to be in sync from what i've tested so far.
    But I can't handle the resulting mkv in in mkvmerge it gives me the error:
    " track 2: Malformed codec id 'A_AAC'."
    I tried to see if i could use the ffmpeg to extract the sound as a wav but the soundfile skips - very odd.
    Feb 2001
    europe
    Hi
    But I can't edit the resulting mkv in in mkvmerge it gives me the error:
  21. You can run it through gdsmux (comes with haali splitter package), and it will re-wrap the mkv, audio id will be fixed (it will be uncompressed audio however - PCM wav). Then mkvmerge or other programs can process it correctly
    Edit: actually better is to demux it with eac3to, and reimport the aac with mkvmerge (this way you keep original audio). It will attempt to fix the bunch of errors and gaps. For some reason mkvmerge doesn't like the original audio id
  22. Member bat999's Avatar
    Feb 2008
    Hi
    The soundtrack needs fixing.
    FFmpeg can do it, like this:-
    ffmpeg -i output90.mkv -c copy -absf aac_adtstoasc new_output90.mkv
    Then it will be accepted by mkvmerge.
  23. Member
    Feb 2001
    europe
    Hi
    Wow, that's great bat, I have no idea what those arguments mean, but they did the trick - and all even seem to be in sync
    Thanks a lot!
  24. Member
    Feb 2001
    europe
    Hehe, I tried looking -absf up in the ffmpeg manual and it says "Deprecated, see -bsf" - which seems to be missing
  25. Member bat999's Avatar
    Feb 2008
    "Deprecated, see -bsf" ...
    Hi
    The up-to-date (not deprecated) command is:-
    ffmpeg -i output90.mkv -c copy -bsf:a aac_adtstoasc new_new_output90.mkv
    aac_adtstoasc is mentioned here ---> http://ffmpeg.org/ffmpeg.html#aac_005fadtstoasc
    But there's no explanation, lol
  26. Member
    Feb 2001
    europe
    I guess it converts adts to asc - how did you find out?
    Btw, if I remove the time argument it just keeps grabbing which is fine.
    But when i press ctrl -c it asks me if I'm sure I want to stop. You don't happen to know a command that will make it not ask, but just stop?
  27. Member bat999's Avatar
    Feb 2008
    ... I guess it converts adts to asc - how did you find out?
    We've had problems with audio in downloaded flv files, sometimes the bsf cures it.
    ... Btw, if I remove the time argument it just keeps grabbing which is fine.
    The "-t 30" option was there just to grab a sample. It's OK to remove it.
    ... You don't happen to know a command that will make it not ask, but just stop?
    Close the window, X in top corner.
  28. Member
    Feb 2001
    europe
    Handy.
    Now i just need something to cut it visually. VideoRedoDo doesn't work, it seems to drop sound frames, making huge drop outs in the sound. Oh well.
    Yeah, I tried just having it running to today and it grabbed 4 hours and 21 minutes and then strangely just stopped.
    Hehe.
    Well, now i guess I need another app to monitor if this one stops and then restart it
    Probably outside the scope of this forum though
  29. Member
    Feb 2001
    europe
    Yeah screen capture is an unnecessary generation loss, plus you can't use the machine for something else meanwhile.
    ffmpeg crashes or skips a lot, but perhaps these bugs will be ironed out over time.
  30. Member
    Mar 2002
    Kirkland, WA
    I get you - I try to steer clear of lossy options as well, but sometimes the trade-off for time and simplicity wins my compromise.
    Have you tried anything that might work with Wireshark?
