Trying to open an MP4 File that:
- was packaged to only work in a home grown application
- problem is developer is no longer around, and i need to edit the video files
When trying top open the video file, I receive an error stating
- unsupported format
- file may be damaged
The video plays fine in the custom user interface application that was developed.
It appears there is some type of block for this to only play in the custom application.
Anyway to get around this and play in other applications?
no.
"When trying top open the video file, I receive an error stating"
These are common system errors ... with what application did you try to open the files with ?
"The video plays fine in the custom user interface application that was developed"
More info on the application ?
If you have a sample file which is less than 100mb you could upload it for others to attempt recovery unless they are security related ... its your choice. -
Also, just to be safe, run one of the videos through MediaInfo, with MediaInfo set to Tree/Text mode, copy all the information it gives you about the video and post it here (blank out the file and folder names, if you want).
If cameras add ten pounds, why would people want to eat them? -
Hello,
You could try to preview your unplayable file with http://mp4repair.org
This file probably contains correctly encoded media, that can be reindexed using a video repair tool like mp4repair.org
Of course, this won't work if the file has some encryption scheme.
-- Benoît -
If it's encrypted or uses a proprietary codec you could record it with a capture tool. I've used Mirillis Action to screen cap videos and they come out pretty good.
How to change date and time of MP4 (or any format) video file ?
By chetan_bokhani in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2012, 12:19 -
How Do I Convert an MP4 file to Windows Movie Maker format?
By gasjkh22 in forum AudioReplies: 7Last Post: 28th Aug 2011, 05:13 -
Memory card video file in .MP4 format does not play
By wakawaka54 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2011, 02:54 -
MP4 file (h.264 format) to avi help
By hak741 in forum Video ConversionReplies: 6Last Post: 18th Nov 2010, 00:51 -
decode/decrypt mp3,mp4, ipod, mov etc to avi to burn to dvd
By brightpenny in forum Video ConversionReplies: 1Last Post: 16th Sep 2009, 16:24
