VideoHelp.com Forum
  1. Ok im not nessesarly new to burning and vcds and such but I am having a problem....
    I have a full length movie (vcd ,2 discs), and its set up in such a manor for me all I do is load the cue and burn.My problem is I load the cue up and burn it, it burns all the way says succesful, but I pop the bad boy in my cd-rom to check it out and theres nothing on the disc!....I check the size of the disc...it says space used 486 megs,look on the bottom of the disc and found something burned.....however the movie (.mpg i extracted from the bin) is 542 megs and the movie works fine.
    I think the problem lies in the cue here are some details of my burn.
    I just need someone to tell me if the cue looks right.
    files:
    ctp-blade2a.bin
    ctp-blade2a.cue
    I extracted the files from the bin there are 2 .avi's, one is an intro
    of the group that made the movie the other is the movie.
    (names of these .mpgs dont matter its the time im concerned about)
    name/length
    intro.mpg 00:40
    blade2.mpg length 54:25
    here is what ctp-blade2a.cue has in it.
    FILE "ctp-blade2a.bin" BINARY
    TRACK 01 MODE2/2352
    INDEX 01 00:00:00
    TRACK 02 MODE2/2352
    INDEX 01 00:06:00
    TRACK 03 MODE2/2352
    INDEX 01 00:54:56
    Im no expert on vcds but it says there are 3 tracks when I have 2 .mpgs
    Is this normal?
    Also im assuming track 2 and 3 are the movie files (intro and movie)
    Im also wondering if this:
    INDEX 01 00:06:00
    means the time of the track (movie) if so they dont really match up
    since I havent had much trouble burning ever and the cue essentially tells the burning program (im using cdrwin) how to burn the bin and cdr win says the burn is fine but there are no files on the disc Im wondering if its the cue....
    can sombody help me out ... does this look right if so where is my problem then, in the burner or in the cue, am I doing somthing wrong if so what???
  2. Originally Posted by Jordan02
    Are you using a cracked version of CDRWin? If so, it's sneaky isn't it?
    http://www.vcdimager.org/guides/burn...in_images.html
    name/length
    intro.mpg 00:40
    I take it you mean there are two video clips?? This is a CUE/BIN image of a VCD or SVCD right and not of a CD-ROM with AVI files?
    Is this normal?
    Yes. For S/VCD, the first track contains data and logical information. The first video track starts on the physical track 2.
    INDEX 01 00:06:00
    That means that the track starts at 6 seconds into the disc. This is normal as the first track (data) is usually 6 seconds long if it doesn't have any additional material (e.g., still images, CD-i app, etc.)
    Regards.
    Michael Tam
    w: Morsels of Evidence
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. Having trouble with .bin/.cue files
    By UncleBose in forum Software Playing
    Last Post: 12th Jan 2008, 06:06
  3. cue,bin converting to dvd?
    By zziem in forum Newbie / General discussions
    Last Post: 7th Aug 2007, 10:36
  4. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
  5. How to merge 2 cue/bin to one DVD
    By motleycool in forum Newbie / General discussions
    Last Post: 7th Jun 2007, 21:26
