What I want to do Is make a menu using VCDEasy. The catch is: I want to be able to put the disk in, have it play a short intro video then goto the menu.
intro>menu>movie/misc
Is this possable, if so how do I do it.
Thanx
That shouldn't be a problem. First check out the guide in the "How to's" forum. This guide describes how to create menus using stills, but you could easily use a motion mpeg instead of (or in addition to) the stills. Just make your movie intro the first item in the sequence, and have it "timeout' to the 1st menu (should be the default if you've ordered them properly).
Also, make sure your using version 1.0.9 if you want to add stills.
I did read the guide. Just didnt know if you could have the still menu as the 2nd track or if it had to be the 1st.
Thanx
:O
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 12:12 -
Menu Question
By coloradoguy in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2009, 01:04 -
Subtitle question for PS3 owners and experts....
By siratfus in forum SubtitleReplies: 1Last Post: 25th Jul 2008, 23:27 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
This Is A Loaded Question For You Video/Audio Experts Out There...
By pmolson in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 13:32
Statistics
Newest guides
Latest tool updates
New media comments
