i try to convert a vob file with VirtualDub and after i used codec of cedocida. but when i mark for 'full prossesing mode' in the audio tab the prosses is stack and i get this massege:
no audio decompressor could be found to decompress the sourse aoudio format
The audio error message is telling you that you don't have the proper audio codec installed in your system. Free software like MediaInfo can give audio info from video clips.
You haven't specified where this "vob" came from. Is it from a standard DVD? IF so the vob is probably some form of MPEG. Try changing its filename from name.vob to name.mpg. Also, DGIndex can read vob's and extract video + audio for use as AVI's and uncompressed .wav audio. There ,ust be dozens of ways to read and manipulate vob's.
Where did the vob come from? What do you want to do with it?Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
Then I take it, this from a home-made DVD?
"MesiaInfo" is MediaInfo. Free. When you see these software names in red in the forum text, click on it to go to a link for that software. They are listed in the tools and guides sections of the forum. Look over these suggestions and pick your choice. Most have pretty good guides, fairly easy to use. But if you have a problem with any one, pick a video as sample and post your specific problems. Plenty of members here can help.Last edited by sanlyn; 8th Jul 2012 at 19:59.
i use "Format Factory" for all my conversion needs - it also fixes broken video files while converting on the fly
How to covert from .mts to .avi or .wma?
By bx510 in forum Video ConversionReplies: 112Last Post: 28th Mar 2013, 06:57 -
Covert .VOB to AVI with out losing quality. How ?!
By SB4 in forum Video ConversionReplies: 7Last Post: 29th Feb 2012, 18:46 -
How do I covert MKV to AVI ?
By Kevin72 in forum Video ConversionReplies: 6Last Post: 11th Jan 2012, 05:47 -
covert flv to standalone compatible avi
By Pitorasilo in forum Newbie / General discussionsReplies: 3Last Post: 8th Dec 2010, 21:40 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40
