ok I have several Blurays that I want to make an Backup of and try to convert them to mkv.
when I use software to demux from the Bluray disc. it demux it I get one left.h264 and one right.h264.
and the audio. the right eye is smaller in size but What I read thats normal because the right eye is that way.
the proble mis that left eye h264 can be muxed into an mkv to be easier to work with or can be converted direct to any format with any encoder.
but the right eye file canīīt be muxed with mkvmerge or it canīīt be encoded with ffmpeg or mencoder.
So why is it that way what can I do to get it to work.
I have try both BDtoAVCHD ssifsucka and they canīīt convert it. they can just demux the streams.
A BD3D is encoded, NOT with AVC (h.264), but with MVC. There are 2 stream types within those files, "main view" (compatible with standard AVC) for the left, and "dependent view" (brand new type that is incompatible with anything else) for the right.
You do not want to do just a straight demux, you want to demux the left (main) and then apply the differences from the demuxed dependent file to the main file to arrive at the right view which can then be encoded to avc or something else.
If those apps cannot do that, use different apps (may cost money, though).
Scott -
Be unusual ... Software used to rip title not mentioned but at a suggestion it's possible this is NOT a 3D bluray being converted.
In bd3d both streams are same size ... I have yet to see any 3d title where this is not the case
virtualdubmod will not work with mkv file containing avc1 codec
By impmon2 in forum Video ConversionReplies: 5Last Post: 5th Nov 2009, 11:48 -
.hs64 stuttering playback
By realdanielh in forum ffmpegX general discussionReplies: 1Last Post: 28th Aug 2009, 13:26 -
mux .sup subtitles in to .mkv Is this possible?
By sdk83 in forum SubtitleReplies: 3Last Post: 5th Nov 2008, 12:47 -
Mux .sup (standard definition) into MKV file too. Impossible?
By sdk83 in forum DVB / HDTVReplies: 1Last Post: 4th Nov 2008, 07:21 -
recode mkv file to work with DXVA
By Smile_M in forum Newbie / General discussionsReplies: 7Last Post: 30th Jul 2008, 18:30
