  1. I have searched the web to download a specific xvid version which is 1.3.127 I had it on my computer and it worked fine with Virtualdub as a matter of fact it worked great. i DOWNLOADED the new 1.3.2 and am having problems with it. I back installed version 1.2 and it worked but doesn't have the user settings I want. I really want back my version 1.3.127 of xvid. Where can you download previous specific versions, I have looked everywhere. xvid.org doesn't seem to let you download previous versions.
  2. VH Wanderer Ai Haibara's Avatar
    You can find some older versions on VideoHelp's Tools page for Xvid: http://www.videohelp.com/tools/XviD-Codec/old-versions#download
    (or just visit the page normally and click on the "Download old versions" link). I don't think it has that specific version archived, but you might find another version that you prefer.
  3. Member rickydavao's Avatar
    Even among similar versions there can be differences, depending on who compiled it. Which user settings are you missing? I'm using 1.3.2, and it's got the most settings and profiles of any of the versions I've used before.
    I've attached a copy of the installer for the version I'm using, in case you'd like to try it.
  4. inactive El Heggunte's Avatar
    Maybe you're looking for the Xvid build by Nic
    http://nic.dnsalias.com/
