Hi Again,
Still having issues with converting multiple MP4 files. Originally I had an FFMpeg problem. Installed FFDshow and Haali media splitter and everything seemed fine.
AFter the first file is converted as note pops up to back up the audio. This only happens after the first title is completed. I click yes and the conversion continues seemingly successfully.
Playing back the files to check the Title 1, the 1st video/audio/w subs plays fine. The titles 2,3 and 4 have no audio at all.
Converting 4 titles is well over 4450. So I am in the process of trying to convert 3 titles instead of 4 to see if this helps
help
many thanks again
<5/30/2012 8:09:13 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 4
DVD Size: 5404/4450 MB (121%)
DVD Output Setup: DVD Folder
DVD Label: 2-Will It Snow at Christmas Ep 5-8
DVD Menu: Motion Menu
Output Folder: F:\K Drama\Will It Snow at Christmas\Will It Snow at Christmas-DVD
Delete Temp Process Files: No
Delete Working Files: No
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
PAL SpeedUp: 0
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Arial 18pt (255,255,0)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: MATSHITA DVD-RAM UJ862ES 1.90
DVD Burning Speed: 8x
Auto Erase DVD RW: 1
Save Log file: 1
Display errors messages: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
Save General Settings: 1
TITLE 1 SOURCE FILES
Video: F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.mp4
Info: AVC - 400 kbps - 624x352 - DAR 1.773 - 29.97 fps (CFR) - Progressive - 1:05:47 hours - 118299 frames
Audio 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.mp4
Info: AAC LC-SBR - 40 kbps - VBR - 2 ch - 48000 / 24000 Hz - 1:05:46 hours (0 ms delay) - Internal
Subs 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.srt
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,480,0,0,0,-0)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 1176.3 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.HCenc.log
*MAXBITRATE 9000
*BITRATE 2500
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<5/30/2012 9:04:19 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.m2v (1177.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2515 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive (TFF) - 1:05:47 hours - 118299 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.ac3"
<5/30/2012 10:09:39 PM>
START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "F:\K Drama\Will It Snow at Christmas\Will It Snow - 05.mp4" -y -vn -acodec ac3 -sample_fmt flt -ar 48000 -ab 192k "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.ac3"
<5/30/2012 10:10:50 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
A2DAudioSource: DirectShowSource
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.ac3 (90.3 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:05:46 hours (0 ms delay)
START SUBS ENCODING OPERATIONS (Track 1)
SRT fixing routine applied (14 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<5/30/2012 10:11:00 PM>
END SUBS ENCODING OPERATIONS (Track 1)
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.sup (1.49 MB)
TITLE 2 SOURCE FILES
Video: F:\K Drama\Will It Snow at Christmas\Will It Snow - 06.mp4
Info: AVC - 400 kbps - 624x352 - DAR 1.773 - 29.97 fps (CFR) - Progressive - 1:05:50 hours - 118405 frames
Audio 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 06.mp4
Info: AAC LC-SBR - 40 kbps - VBR - 2 ch - 48000 / 24000 Hz - 1:05:50 hours (0 ms delay) - Internal
Subs 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 06.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 06.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 06.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Target Video FileSize: 1177.5 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.HCenc.log
*MAXBITRATE 9000
*BITRATE 2500
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<5/30/2012 11:24:36 PM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.m2v (1178.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2515 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive (TFF) - 1:05:50 hours - 118405 frames
Wavi+Aften Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.ac3"
<5/30/2012 11:25:21 PM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.ac3 (90.4 MB)
SRT fixing routine applied (10 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<5/30/2012 11:25:35 PM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.sup (1.55 MB)
TITLE 3 SOURCE FILES
Video: F:\K Drama\Will It Snow at Christmas\Will It Snow - 07.mp4
Info: AVC - 400 kbps - 624x352 - DAR 1.773 - 29.97 fps (CFR) - Progressive - 1:07:03 hours - 120585 frames
Audio 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 07.mp4
Info: AAC LC-SBR - 40 kbps - VBR - 2 ch - 48000 / 24000 Hz - 1:07:03 hours (0 ms delay) - Internal
Subs 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 07.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 07.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 07.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Target Video FileSize: 1199.2 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.HCenc.log
*MAXBITRATE 9000
*BITRATE 2500
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<5/31/2012 12:45:01 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.m2v (1199.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2515 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive (TFF) - 1:07:03 hours - 120585 frames
Wavi+Aften Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.ac3"
<5/31/2012 12:45:45 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.ac3 (92.1 MB)
<5/31/2012 12:45:46 AM>
SRT fixing routine applied (1 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<5/31/2012 12:45:54 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.sup (1.52 MB)
TITLE 4 SOURCE FILES
Video: F:\K Drama\Will It Snow at Christmas\Will It Snow - 08.mp4
Info: AVC - 400 kbps - 640x360 - DAR 1.778 - 29.97 fps (CFR) - Progressive - 1:06:06 hours - 118866 frames
Audio 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 08.mp4
Info: AAC LC-SBR - 40 kbps - VBR - 2 ch - 44100 / 22050 Hz - 1:06:06 hours (0 ms delay) - Internal
Subs 1: F:\K Drama\Will It Snow at Christmas\Will It Snow - 08.srt
AVISYNTH SCRIPT
Video = A2DVideoSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 08.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp", FrameRate=29.97, VFR=false)
Audio = A2DAudioSource("F:\K Drama\Will It Snow at Christmas\Will It Snow - 08.mp4", CacheFolder="C:\Users\Steve\AppData\Local\Temp")
Video = Video.Lanczos4Resize(720,480)
Audio = Audio.SSRC(48000)
Target Video FileSize: 1182 MB
HCenc Parameters: -ini "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.HCenc.ini"
HCenc ini file:
*INFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.avs
*AVSRELOAD
*OUTFILE C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.m2v
*LOGFILE C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.HCenc.log
*MAXBITRATE 9000
*BITRATE 2500
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 20
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<5/31/2012 2:00:49 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.m2v (1182.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 2515 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive (TFF) - 1:06:06 hours - 118868 frames
<5/31/2012 2:00:50 AM>
Wavi+Aften Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.ac3"
<5/31/2012 2:04:30 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.ac3 (90.8 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:06:06 hours (0 ms delay)
<5/31/2012 2:04:31 AM>
SRT fixing routine applied (2 lines fixed)
SubtitleCreator Parameters: "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.srt" -p4 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
<5/31/2012 2:04:38 AM>
Created File: C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.sup (1.6 MB)
<5/31/2012 2:04:39 AM>
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Menu in Black
Max Titles Page: 12
Enable Play All: 1
Force Play All: 0
Background Audio: 0
Max Thumbs Row: 4
Thumb Image Source: 0
Thumb Frame Position: 25%
HL Frame Format: 0
HL Selection Color: 5
HL Play Color: 0
Menu Video BitRate: 6000 kbps
Motion Menu Duration: 15 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<5/31/2012 2:06:27 AM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_MenuPage1.m2v (10.7 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_BatchMux.ini"
BatchMux ini file:
-d "F:\K Drama\Will It Snow at Christmas\Will It Snow at Christmas-DVD\2-Will It Snow at Christmas Ep 5-8_0\VIDEO_TS"
-mxp "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_MuxMan.mxp"
-l "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-palette "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_Palette.txt"
-v "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05.m2v"
-vidmode LB
-a1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.ac3"
-a1lang en
-s1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_1.sup"
-s1lang en
-s1ext 1
-cellfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_Chapters.txt"
-progfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_Chapters.txt"
-chapfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_01_Will It Snow - 05_Chapters.txt"
-SEG2v "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06.m2v"
-SEG2vidmode LB
-SEG2a1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.ac3"
-SEG2a1lang en
-SEG2s1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_1.sup"
-SEG2s1lang en
-SEG2s1ext 1
-SEG2cellfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_Chapters.txt"
-SEG2progfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_Chapters.txt"
-SEG2chapfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_02_Will It Snow - 06_Chapters.txt"
-SEG3v "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07.m2v"
-SEG3vidmode LB
-SEG3a1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.ac3"
-SEG3a1lang en
-SEG3s1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_1.sup"
-SEG3s1lang en
-SEG3s1ext 1
-SEG3cellfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_Chapters.txt"
-SEG3progfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_Chapters.txt"
-SEG3chapfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_03_Will It Snow - 07_Chapters.txt"
-SEG4v "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08.m2v"
-SEG4vidmode LB
-SEG4a1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.ac3"
-SEG4a1lang en
-SEG4s1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_1.sup"
-SEG4s1lang en
-SEG4s1ext 1
-SEG4cellfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_Chapters.txt"
-SEG4progfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_Chapters.txt"
-SEG4chapfr "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Title_04_Will It Snow - 08_Chapters.txt"
-SEG5v "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_MenuPage1.m2v"
-SEG5vidmode LB
-SEG5s1 "C:\Users\Steve\Videos\2-Will It Snow at Christmas Ep 5-8_0_Menu.sst"
-SEG5s1dmode WIDE_LB
-SEG5hlmnu "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_MenuPage1_Buttons.mnu"
-SEG5hlcsm "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_HighlightScheme.csm
-hcn "C:\Users\Steve\AppData\Local\Temp\2-Will It Snow at Christmas Ep 5-8_0_BatchMux.hcn"
<5/31/2012 2:17:11 AM>
CHECK DVD SIZE
DVD Folder (actual) Size: 5275 MB
vs Estimated Size: 5404 MB -> 2.4% undersize
vs Assets Size: 5118.3 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: F:\K Drama\Will It Snow at Christmas\Will It Snow at Christmas-DVD\2-Will It Snow at Christmas Ep 5-8_0 (5275 MB)
Log file created by AVStoDVD Release 2.4.2
Results 1 to 10 of 10
More info,
After the 1st title was complete, a warning popped up that said Warning Errors found during audio Track 1 encoding. Do you want to start back up Audio encoding routine.(ffmped based).
clicked yes and back up began. All I could see was" Seems 0 codecs differs from container frame rate 59.94/29.87/50 - 29.97 (30000/1001). Thats all I could get before the window closed, nowhere to be found.
This doesn't happen after the following titles, but titles 2,3 and 4 are the ones that the audio is missing.
many thanks -
@stem300
why haven't you continued the previous thread on the same source files conversion?
http://forum.videohelp.com/threads/346544-AVSTODVD-ffmpeg-stopped-working?p=2165265&vi...=1#post2165265
BTW, if you are having issues with Wavi+Aften AC3 encoders (title 2,3,4), you can go to 'Preferences'/'Audio' and select 'FFmpeg' as AC3 default encoder.
Bye -
Thank you for the reply.
I thought that this is a separate issue.
Tried your advice, selected FFmpeg in Audio Preferences. The video conversion is still okay, however, instead of no sound, the sound is very distorted in all of the titles 1-4.
Please advise.
many thanks again -
Thank for the reply Mr.C,
Where can I up load the titles. This drama consist of 16 episodes. I can give you the website that I got this from. (rar files). Not sure if this is okay.
My plan was to convert 4 episodes per even though the size is over 4450. I would then use a shrink program to make it fit. I've done this many times before with no problem. I converted 3 episodes which is within the 4450 size and that didn't matter.
Back to the 16 episodes, only episode 1 plays well. Episodes 2,3,4 have no audio. Episodes 5,6,7,8, Episodes 9.10,11,12 and Episodes 13,14,15,16 all have distorted audios.
please advise. many thanks againLast edited by stem300; 2nd Jun 2012 at 03:31.
@stem300
are you sure the drama episodes come from a "safe" source? I mean legal, no warez or something like that. The consistency and quality of the source is essential to get good results on the output DVD.
If the answer is positive you can post the website link
Bye -
Here is the site. scroll to the lower half.
http://doramax264.com/7649/will-it-snow-at-christmas-k-drama-210mbeps/ -
Thanks Mr C,
I'll give this a try and get back
thanks
No Audio when converting MKV to DVD using AVStoDVD?
By |StarscreaM| in forum Video ConversionReplies: 14Last Post: 8th Jan 2013, 23:57 -
Converting VOB files from Sony HandyCam to MP4 or MOV
By electrox73 in forum DVD RippingReplies: 3Last Post: 8th Jan 2011, 05:46 -
Problems converting m2ts with subs in AVStoDVD
By eon_designs in forum Blu-ray RippingReplies: 6Last Post: 12th Dec 2009, 07:03 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 18:20 -
After converting to mp4, Ellion 950-s recognises disc, but not files within
By anlaoch in forum DVD RippingReplies: 3Last Post: 2nd May 2008, 09:06
