Hi,
I've been using VirtualDub for captures and it worked well but suddenly, it freezes during the capture - the frames captured number etc don't change.
Are there any suggestions how to diagnose the problem? Could it be connected with resolution/yuy2/codec?
Thanks.
Usually such problems with any software are cured by reinstalling it.
Beyond that we need more info to help you. -
Some questions you should ask yourself.
What am I doing differently ?
Have I installed any other software (background programs) since I last did a successful capture ?
And it would be useful to know:
1. Your capture device. Has that changed ?
2. Your OS. Has that changed ?
3. No of HDDs
The list is endless.
Vobsub freezes when installing and selecting the directory for virtualdub
By toprun91 in forum SubtitleReplies: 3Last Post: 9th Dec 2016, 10:40 -
Capture Freezes on all programs
By Justinpd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 18:05 -
Pressing Capture Button Freezes Program
By Mengsk in forum CapturingReplies: 13Last Post: 5th Jun 2008, 17:45 -
DirectShowSource freezes VirtualDub
By PlayWithFire in forum Newbie / General discussionsReplies: 3Last Post: 11th Oct 2007, 02:07 -
VHS capture freezes applications
By RedFarmer in forum CapturingReplies: 4Last Post: 20th Aug 2007, 12:00
