Results 1 to 11 of 11
    Is it possible to repackage mp4 files to the matroska container without reconverting and playback issues? MP4 is kinda jerky and unstable as a format to non-PC environments, and i would like to try mkv instead.
    This is the mediainfo log of said mp4
    General
    Complete name                    : I:\720p\Creator.mp4
    Format                           : MPEG-4
    Format profile                   : Base Media
    Codec ID                         : isom
    File size                        : 600 MiB
    Duration                         : 1h 42mn
    Overall bit rate mode            : Variable
    Overall bit rate                 : 816 Kbps
    Encoded date                     : UTC 2011-09-09 03:38:17
    Tagged date                      : UTC 2011-09-09 03:38:17
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 5 frames
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 1h 42mn
    Bit rate                         : 783 Kbps
    Maximum bit rate                 : 3 392 Kbps
    Width                            : 1 280 pixels
    Height                           : 688 pixels
    Display aspect ratio             : 1.860
    Frame rate mode                  : Constant
    Frame rate                       : 23.976 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.037
    Stream size                      : 574 MiB (96%)
    Writing library                  : x264 core 116 r2074 2641b9e
    Encoding settings                : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=5 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=783 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
    Tagged date                      : UTC 2011-09-09 03:38:27
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : HE-AAC / LC
    Codec ID                         : 40
    Duration                         : 1h 42mn
    Bit rate mode                    : Variable
    Bit rate                         : 32.0 Kbps
    Maximum bit rate                 : 59.4 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Sampling rate                    : 48.0 KHz / 24.0 KHz
    Compression mode                 : Lossy
    Stream size                      : 23.5 MiB (4%)
    Encoded date                     : UTC 2011-09-09 03:38:26
    You can try Mkvtoolnix / mkvmergegui. Just add the mp4 and save as/start muxing as a new mkv. Disable also header compression under file->options->disable header removal compression for better compatibility.
    Ok i tried it, i still have to test it this weekend on my ps3 and see if it playasback correctly. Thanks
    I doubt the ps3 support any mkv.
    Try instead stream the mp4 or mkv with ps3 media server if you can.
    No it does. With a piece of software called showtime that runs through homebrew. So this part is not worrisome.My only worry is if mkv supports all the streams that are supported on mp4 files.
  6. MKV will support pretty much any type of audio or video stream supported by MP4, and a lot more. MKV is far more versatile in that respect. I'm not 100% sure about subtitle formats though as I rarely use them.
  7. Member johns0's Avatar
    Mkv supports various types of subtitles(txt,graphics,etc..)
    Ok tried it this weekend and all conversions worked perfectly. I now only need to ask if there's an automated way to repackage in one click mp4 and srt into mkv for lots of files. Cause using mkvmerge to add file 1 + srt 1 and add to job queue, then do the same for movie 2 + srt 2, ...., movie 10 + srt 10 is painful.
    That's true, although once, i remember adding a subtitle format that had text placement, something like xy coordinates and it prompted me that mkv omits this information and views it as a plain file. Just thought i should note that.
    New Question. I had a 2CD avi with vobsub subtitles. Since my standalone player doesnt support the idx/sub format as external but it does inside matroska, i repackaged the xvid stream into matroska along with the subs. It resulted in not having video. Why couldnt my player handle xvid from inside mkv?
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    Try instead AVIAddXSubs and make a .divx/.avi with builtin xsubs.
    I have used it in the past for srt subtitles, but didnt know it can support vobsub.
