I have a simple problem I can't figure out.
We just purchased a brand new Sony camcorder: Full HD HDR-PJ760V. The video quality in my PC is stunning, but once I edit
the movie in my Pinnacle Studio HD v.14 and render it out, it looses quality. For the format I tried: MPEG4 and AVI. They both loose so much quality it almost makes the video not watchable.
Not to mention the rendered file is twice as big comparing to the original video.
Can you guys tell me what I'm doing wrong?
Results 1 to 11 of 11
That's odd, you say it's a brand new camcorder? Was the box sealed from the factory?
The first, logical explanation is that you chose the wrong settings in Pinnacle. AVI is simply a container that can hold anything from crap to uncompressed video(and audio). What was the extension on that "MPEG 4" file you created? What video codec did you use inside that "AVI" file you created?
Sometimes shoplifters do a switcharoo, and you end up with an older model.
There should be render settings to get back to AVCHD or Blu-ray (similar quality), internet upload (compromised and frame rate reduced) or DVD (downsized to 720x480).
60P (AVCHD 2.0) Blu-ray players will be introduced later this year.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
That's ol' slick Sony for you. Turning a bug fix into a version 2.
1920x1080p60 is still useful for direct display to an HDTV or to some computer monitors.
I've discovered 1920x1080p60 or 1280x720p60 work great in Vegas for down conversion to 480i DVD. Each HD frame is individually downsized to a DVD field with no deinterlace artifacts. Same goes for HD 50p to DVD 50i.Recommends: Kiva.org - Loans that change lives.
Rendering Issue with Vegas Movie Studio and GoPro
By Squid_uk in forum Newbie / General discussionsReplies: 11Last Post: 29th Nov 2011, 11:13 -
Sony Vegas Movie Studio 10 rendering problem
By videogirl214 in forum EditingReplies: 1Last Post: 18th Aug 2010, 23:29 -
Uncompressed AVI plays back in low quality with WMP12 & Pinnacle Studio 14
By textmagic in forum Software PlayingReplies: 2Last Post: 2nd Apr 2010, 04:25 -
Pinnacle Studio: Pan and Zoom/Rendering Problem
By ashleyvideogirl in forum EditingReplies: 0Last Post: 18th Jan 2009, 03:30 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum CapturingReplies: 4Last Post: 26th Nov 2007, 18:53
