When I select an MPEG file to be burned into a VCD for some reason VCDEasy ignores the vast majority of the file. (This does not happen with Nero). On every file that I try, it finds data that is not VCD compliant and truncates the file at that point. When I analyze the MPEG file (using VCDEasy) I get a message that some volume of data was not as expected and that the reast of the file will be ignored. I am using the MPEG encoder of Cyberlink's PowerVCRII. Thanks for your help
Thread: VCDEasy truncates my MPEG files
Dear Idaivs,
I have the same Problems.
In My Case I captured TV with Virtualdub (MPEG 4V2); then Make a Conversion to MPEG 2 with SVCD setting described under HowTo with TMPEGEnc 2.53.
All Files were fine.
But in Case of Burning with EasyVCD I have exacly the same Problems.
In the logfile was written:
mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.0b]
mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:08.0c]
mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.0b]
mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:01.0d]
mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:08.0d]
mpeg user scan data: one or more BCD fields out of range for 'previous_I_offset': [00:01.0d]
mpeg user scan data: from now on, scan information data errors will not be reported anymore---consider enabling the 'update scan offsets' option, if it is not enabled already!
mpeg scan: pack header code (0x000001ba) expected, but 0x6b2c76a8 found (buflen = 2324)
bad packet at packet #327799 (stream byte offset 761804876) -- remaining 14694652 bytes of stream will be ignored
Can anyone HELP us
Jürgen
You've probably figured it out by now, but I'll comment anyway incase others have not.
I've had that happen twice now.
I don't know why it happened, but re-encoding the entire mpg made it go away -- must have been a hiccup in TMPGEnc
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 8Last Post: 8th Nov 2010, 14:02 -
DVD recorder truncates recordings
By JosephWebber in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Nov 2009, 10:49 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 07:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
Statistics
Newest guides
Latest tool updates
New media comments
