Results 1 to 14 of 14
  1. the sound and the film are out of sync think the. think the pictuer is to fast
  2. AVStoDVD Author _MrC_'s Avatar
    Post the project .log file (see output folder).
    Bye
    MrC
    AVStoDVD Homepage
  3. Ops, I think I'm having the same problem. This message persists in every videos I've edited recently after I fixed my computer and reinstalled everything in it: "error - could not write to the standard output". The first edited video didn't have any subtitles related to, although the message appeared, it was perfectly syncronized. The last two had the same problem and the message. Their subtitles's code wasn't checked.
    I upgraded ffdshow and Haali codecs, and I don't know if it's really a question of subtitles because the message appeared also in a edition of a video that haven't any and the result was perfect.
    test 1: video without subtitles (message appeared / perfect sync)
    test 2: video with subtitles (message appeared / srt subtitles code unchecked / out of sync)
    test 3: video with subtitles (message appeared / sup subtitles code unchecked / out of sync)
    Could it be because of the location of the output directory (original) or its original name (~user name)?
    Here's the log file of test 2.
    thanks in advance
    true cyber-democracy lies in forums
    some sketches at flickr, reading texts at scribd, tacting ideas at my blog
    This may seem obvious ... the science of troubleshooting often deals with eliminating the obvious first ... but is the sound in sync on the original file?
  5. AVStoDVD Author _MrC_'s Avatar
    @Ze Tomes
    1. Where exactly do you get the message "error - could not write to the standard output"
    2. Regarding test 2, the issue is releated to the backup audio routine (FFmpeg) which does not use the AviSynth script, hence it does not process the PAL speedup. It is very strange that on test 1 you are not having out of synch. Could you please post the log file of test 1?
    Bye
    MrC
    AVStoDVD Homepage
  6. Originally Posted by Hoser Rob View Post
    yes it is
  7. Greetings MrC
    It's after concluding the video encoding, just when it starts the audio edition, that the message appears on a window and stops the process. I have to close it to allow the editing to continue.
    If I recall correctly, after test 1 (2,3,etc) I changed the video general preferences to: (AVStoDVD Preferences > Video > Setup Video Profiles > HCenc VB 1-pass) because
    the next editings would imply the need of subtitles, and by this new process the audio editing was always getting stucked, when subtitles were present I mean. At the previous one (test1) subtitles weren't needed therefore I didn't have to change the video settings, but if I'm not in mistake the error message was already appearing by the same circumstances.
    But of course my friend, here it goes:
    Cheers
  8. AVStoDVD Author _MrC_'s Avatar
    Wait, is the last log file belonging to test 1? How can you say that video and audio are in sync, while video encoding has aborted and audio encoding has never started?
    Bye
    MrC
    AVStoDVD Homepage
  9. Wait, is the last log file belonging to test 1? How can you say that video and audio are in sync, while video encoding has aborted and audio encoding has never started?
    Yes. Video encoding was finished correctly and never aborted, and the audio encoding started somehow after I closed the dos window refering to the error message (error - could not write to the standard output)
  10. I'm suspecting it is somehow connected with the editing directory paths. Testing
  11. Nhahaa! I think I've solved the mystery! It's because of the string text of the output directory! (i was using the directory of my user name with special portuguese caracteres, like c:\users\JAOP~1)... at least it gives major headaches for hackers, I presume...
    No more error message. Waiting for the end of the edition
    Cheers
  12. Case closed, audio and video perfefctly syncronized and no error message > simple output directory with simple ascii caracters. Now for the subtitles... that's another story for which I think I got the solution already. Let me check...
    yup, everything's perfect now, thank you again for yout major work MrC.
    Portugal Cheers!
  13. AVStoDVD Author _MrC_'s Avatar
    Well, you did everything by yourself. You are becoming an advanced user
    Thanks for the solution report
    Bye
    MrC
    AVStoDVD Homepage
  14. And that makes me proud, being useful both to the forum and your work! It's the least I can do, contributing with my own experiences.
    Cheers
