Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 64
  1. aBigMeanie aedipuss's Avatar
    Originally Posted by JackDanielZ View Post
    If you haven't converted the video yet, try a quick remux with My Mp4box Gui. It will only take a minute or two.
    I havent converted it and I have muxed it now.
    Does the xbox 360 play it?
    can an xbox play 1080 50p at all? i thought 1080p30 was as high as playback went.
    The source video is 1080i25.
    yes but aren't you having him create 50p for his 360?
  4. my code now is:
    Load_Stdcall_plugin("C:\Users\Daniel\Desktop\MeGUI\tools\avisynth_plugin\yadif.dll")
    ffVideoSource("C:\Users\Daniel\Desktop\sample.ts", seekmode=0)
    Yadif(mode=1, order=1)
    LanczosResize(1280,720)
    I did the script abbove and the 720p50.mp4 on here is still way better.. my result is also very slow and has trouble playing..
    Where to put the ffmpegsource2 I have put the file in there C:\Program Files (x86)\AviSynth 2.5\plugins\FFMS2.avsi
  5. its okay with the xbox thing I bought a ekstra HDMI cable to day and I will put it in my TV
    i don't think an xbox can play any video over 25/30p no matter how it's connected to the tv.
  7. Originally Posted by aedipuss View Post
    Hdmi fra Pc to TV
    He said the 720p50 video I uploaded played properly.
    Yes it did.. the best result is still 720p50 do you still have the excat avisyth script for that?
    When you encode the file how do you do it? I use MeGui ? is that what I should use?
    I gave you the exact script. I didn't use MeGUI. I used the x264 CLI encoder. That's why I didn't bother with audio. I think this is the command line I used:
     x264.exe --preset=slow --ref=3 --bframes=2 --keyint=100 --crf=20 --sar=1:1 --output %1.mp4 %1
    I fyou have ffms2.avsi in your AviSynth plugins folder all you have to do replace ffvideosource("sample.ts") with ffmpegsource2("sample.ts", atrack=1) in your script.
    Now the soundthing is in place.. I hope this is my last question.. Where should I put the code?
    I found out were to put it but got an error
    I don't really use MeGUI. But as far as I know you just open the AVS script in MeGUI. I forgot, you'll probably need the seekmode=0 argument in the ffmpegsource2("sample.ts", atrack=1, seekmode=0) line. Don't expect MeGUI to preview the video smoothly. But the video you make should play smoothly.
  13. It worked fine and I got the wanted quality THANK you all so much..
    One thing diddent get the sound but I think I forgot to put it on when encoding with megui..
  14. Originally Posted by jagabo View Post
    ffvideosource() won't give you sound. You need to use ffmpegsource2("video.ts", atrack=1) if you want both video and audio. It's in the AVSI file, that's why I told you to put it in your plugins folder along with the dll.
    ok nice, thanks
  15. Member johns0's Avatar
    JackDanielZ-in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time.
  16. Originally Posted by _Al_ View Post
    ok nice, thanks
    Done the FFMS2.avsi is in the avisynth plugin folder.. and thank you.
    Here is my Avisynth filers Hope its okay
    I don't see ffms2.avsi in there. Oh, nevermind. It's on the first line with the extension hidden.
  18. Originally Posted by jagabo View Post
    has it something to to with the extension being hidden?
    my script right now:
    ffmpegsource2("soccer.ts", atrack=1, seekmode=0)
    When I open the file with VDUB I can hear the sound in the slowmotion preview.
    Don't worry about preview. Your computer simply isn't fast enough to preview the script. Just encode the video. If the final encoded video doesn't play properly, then you have a problem.
  20. I uninstallet it all.. is DGAVCIndex the same as DGindex because I cant get DGindex to work. If i uses DGAVCIndex should I then put libavcodec.dll and DGAVCDecode.dll in the avisynt filter?
    No. DgIndex is for MPEG 2 video. DgAvcIndex is for h.264 video.
  22. Originally Posted by jagabo View Post
    What do i do then when I cant get DGindex to work "no sequence header video find"
  23. Member
    Your video is AVC, not MPEG 2. So you must use DgAvcIndex. DgAvcIndex and libavcodec.dll must be in the same folder, anywhere you want to put them. DgAvcDecode.dll goes in the AviSynth plugins folder (or you can use LoadPlugin() in your script to load it from elsewhere). When you want to open a file using DgAvcdecode you use AvcSource("filename.dga"). So you script would be:
  24. Member
    dgavcdec is no longer developed or supported for a few years - beware you can get major decoding issues (macroblocking) with interlaced avc (PAFF) streams.
  25. Member
    It seemed to work ok with the OP's sample.
  26. Member
    His is actually MBAFF stream, not PAFF. It fails on many PAFF streams. Well documented issue dating back years, but it occassionally has issues with MBAFF streams as well . I would check in more detail on longer samples to be sure
  27. Member
    Sure, but he's probably only going to watch this video once. A few errors here and there may not matter. The sample was two minutes long and I saw no problems with AvcSource(). Since it was a soccer game I doubt the rest of the game is any different.
  28. I have tried anything I cant get sound in Megui i use this:
    Load_Stdcall_plugin("C:\Users\Daniel\Desktop\MeGUI \tools\avisynth_plugin\yadif.dll")
    When I open the script in VDUB there is sound.. Last thing I need sound in my MeGUI then I am done asking when it succeeds. Thank you all for the help..
  29. Member
    megui encodes audio separately unless you use the 1 click encoder or autoencode. Notice there is a separate video section and an audio section, you would mux them together in a separate step
    It's not the easiest gui to use. Something like ripbot would be easier to use, especially if you've already made your script
    (But if you've already encoded the video, don't waste it (video takes longer than audio to encode), just encode the audio and mux it in with the mp4 muxer in the tools menu)
  30. Originally Posted by JackDanielZ View Post
    MeGui could be tricky if you tackle it first time, follow this video, settings might be different then overthere you choose some HD template: http://www.youtube.com/watch?v=qR5hd7G3iFQ&t=2m10s
