I just signed up for a service that lets me listen to streaming audio of archived radio broadcasts. A pop up window pops up and it says Media Player-Windows Internet Explorer. Is there a way to save this audio to my hard drive as an mp3 file?
Thread: Capturing audio
Try either StreamHijacker or StreamTransport. I don't do this much, but I've been able to use one or the other in the past to save audio streams. However, I think they just save the streams as they are, so if it's not MP3 you will have to convert after saving. But that is the easy part. Saving the stream is the harder task. If for some reason you can't get either to work, you'll likely need to use a commercial solution like ReplayMediaCatcher.
Thanks. How large will these files be for something around 3 hours?
I wonder if Audacity will work for this as well and would it be easier?Last edited by kschwi; 25th Apr 2012 at 14:30.
Audio Capturing from Computer
By Tahlos in forum AudioReplies: 11Last Post: 29th Nov 2010, 18:42 -
Sony Vegas Capturing Outside Audio instead of MiniDV Audio
By RKelly in forum CapturingReplies: 3Last Post: 29th May 2008, 08:22 -
RE-Capturing Audio
By Casper_H in forum CapturingReplies: 1Last Post: 16th Apr 2008, 10:23 -
capturing dv audio only
By Driber in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 25th Feb 2008, 10:36 -
Help capturing line in audio
By djain91 in forum AudioReplies: 1Last Post: 22nd Nov 2007, 17:58
