Anyone know how to easily join lossless AVI files like largarith, Huffuyv, UTcodec, etc?
When I want to create a lossless master file from several large Premiere project exports, the join using "append AVI" never works in VirtualDub or AVI Demux.
Vdub always says: "Incompatible Data Format - mismatch detected in opaque codec data at byte 28 of the format data".
I've heard you can edit the file headers or something with a Hex editor but if that's the case then I need some guidence using the Hex editor in VirtualDubMod. What I see when I open a file for hex editing is mostly incomprehensible to me.
thanks.
The mean by opening both files in VdubMod with a single Avisynth script and then saving it?
Well it saves, but not right.
I don't want to re-encode - I want to preserve the format of the source (eg. largarith, UT codec, ect). So I choose "direct stream copy" aftre creating the Avisynth file but Vdub saves the new file as a massive uncompressed RGB file, 6 times the combined size of original source files. UPDATE: it seems AVIsynth doesn't support direct stream copy of compressed lossless formats.Last edited by spicediver10191; 25th Apr 2012 at 06:47.
You are not able to join different codecs in one AVI - if codec is lossless then decompresing and recompressing will not change anything - You need to re-encode anyway or to uncompressed or losslessly compressed with only one codec - limitation is AVI container.
Yes you're right, I can recompress/re-encode.
It's just not my preferred method because with large files (60+ minutes) my system sometimes throws up bad frames when I encode with these compressed lossless codecs. By doing it twice I have to re-watch the entire video again and manually remove the new offending frames.
But the AVIsynth method does allow joining, so thanks for that suggestion.
I just wish I could join such files with a direct stream copy - it would save me a lot of time. -
You can try use ffmpeg or mencoder - however not sure what type effect You can expect... and AVIsynth is not able to combine compressed streams - they are uncompressed to RAW format.
Not sure why You use lossless codecs if they are not stable on Your system - personally i use ffdshow huffyuv and i never have problems with wrong frames (what happens sometimes in case of different lossless encoders).
Join 2 AVIs
By phunkidude in forum MacReplies: 2Last Post: 23rd Dec 2010, 14:28 -
VirtualDub Error: The audio streams have incompatible data formats
By UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 02:38 -
Help with incompatible video format, HDV
By LaMaison in forum MacReplies: 6Last Post: 21st Dec 2009, 05:00 -
join 2 AVIs w/ VirtualDub, Truncated or invalid decompressed audio format
By Madgelina in forum EditingReplies: 3Last Post: 6th Mar 2008, 13:25 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 10:06
