Hello,
I have an early 2009 MAC PRO with 2 Dual-Core Intel Xeon 2.66 GHz 64 bit processors. It has a NVIDIA GeForce 7300 GT with 256 MB VRAM, with a color depth of 32 bits.My bus speed is 1.33 GHz. I am trying to run Windows 7 using Parallels software. When I try to load the Parallels, it doesn't run and ejects the CD.
Any suggestions?
Please do not post in 8 year old threads that have nothing to do with your question,i moved your post to the mac forum where someone might understand it.
You say" When I try to load the Parallels..." What version of Parallels are you running?
Is it a legitimate OEM disc? Is the version of Parallels you have for the Mac or for Windows?
Last, what version of the Mac OS are you running?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Wait.. What???
Parallels works fine, but you are trying to run windows 7 off a CD? Parallels should be in your Applications Folder,
Are you trying to Install Parallels? If so, what version of OS are you on, and what version of Parallels are you trying to isntall?
I ask because i'm not sure you can run Parallels version 2 in Mac OSX 10.7
Subtitle Editor Linux - How to Run It on Windows 7?
By devilcoelhodog in forum SubtitleReplies: 3Last Post: 27th Feb 2012, 18:42 -
Parallels Plesk Panel uninstall issue
By leghorn in forum ComputerReplies: 4Last Post: 24th Oct 2010, 07:22 -
Ac3Gain won't run on my Windows 7 64-bit pc
By Jan17 in forum AudioReplies: 12Last Post: 1st Feb 2010, 06:48 -
how to run as admin in CMD in Windows XP?
By jyeh74 in forum Newbie / General discussionsReplies: 7Last Post: 29th Jan 2010, 18:26 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 18:00
