First of all This is my first day here so forgive me if make any mistakes...
I'm tired of searching for methods n tools n experimenting on mp4 to convert its 5.1 in 2 channel so that it can be played via USB On my SONY LED 3D.. There r many tools(mkv all in one) which work flawlessly in converting mkv to mp4+convert 5.1 to 2+add subs... but isnt there even one tool which can convert 5.1 to 2 channel without re-encoding video...?if there is then plz help or if u know any methods doing so plz share.. extracting with yamb then reencoding audio n joining again dont work for me....
Thanks..![]()
Results 1 to 12 of 12
I don't know of any tool that can accept MP4 input, convert the audio, and produce a new MP4 with the new audio. I think you will have to extract the audio and make a new MP4.
Supposedly the program called BeHappy can convert from 5.1 AAC to 2.0 AAC, but as I avoid AAC audio like the plague I have never personally tried this. -
Hi
Try with FFmpeg from here ---> http://ffmpeg.zeranoe.com/builds/
Code:ffmpeg -i filename.mp4 -c:v copy -c:a aac -strict experimental -b:a 128k -ac 2 -scodec copy new_filename.mp4
Update: slightly updated.
Here is a batch file to downmix the audio from all mkv's in current directory to 2.0 stereo via eac3to Dolby Pro Logic II conversion. Then it will recompress the downmixed audio via Quicktime AAC TrueVBR. Then it will remux the source video and the 2.0 AAC audio to a new MKV file.
You will need to specify the paths to eac3to, mkvmerge (from MKVToolNix), and qaac.exe. All 3 of these tools are available for free from the Internet.
HTML Code:@echo off set PATH_EAC3TO=D:\VideoProcessing\eac3to327 set PATH_MKVMERGE=D:\VideoProcessing\mkvtoolnix-unicode-5.9.0 set PATH_QAAC=D:\VideoProcessing\qaac for /f %%a IN ('dir /b *.mkv') do ( echo ---------------------- BATCH STARTING %%~na%%~xa %PATH_EAC3TO%\eac3to.exe "%%~na%%~xa" -log="%%~na.eac3to.log" 2: stdout.wav -downDpl | %PATH_QAAC%\qaac.exe --tvbr 90 --quality 2 --rate keep --no-delay - -o "%%~na.m4a" %PATH_MKVMERGE%\mkvmerge.exe -o "%%~na-stereoremux.mkv" --compression -1:none -A -S "%%~na%%~xa" --language 0:eng --compression 0:none -a 0 "%%~na.m4a" -D -A -M -B -T --no-chapters --no-global-tags "%%~na%%~xa" ) -
Assuming it's an mp4 as above.
Create a folder in the C drive called ffmpeg
Copy ffmpeg.exe to the folder.
Copy the source mp4 file to the folder.
Change the name of the mp4 file to filename.mp4
Highlight and copy the following string:
Browse to and highlight the ffmpeg folder.ffmpeg -i filename.mp4 -c:v copy -c:a aac -strict experimental -b:a 128k -ac 2 -scodec copy new_filename.mp4
Hold down the shift key and right click on the folder.
Select 'Open command window here'.
Paste the string and <enter>
Or, click Start, type run <enter>, type cmd and click 'OK'.
The command screen pops up.
Type:
cd c:\ffmpeg
Paste the string and <enter> -
Much appreciated. Thank you.
Out of interested is there another line to convert AC3 to AAC?
Thanks again
Greg -
Google for the particular conversion you want.
This is an mpeg file converted to mp4 with aac stereo.
ffmpeg -i source.mpg -b:v 8000k -ab 128 -ac 2 clip.MP4
These values replace the default that ffmpeg uses - (I'm not sure what the default values are).
-b:v 8000k = video bitrate 8mb/sec
-ab 128 = audio bitrate 128 kilobits/sec
-ac 2 = audio to have 2 channels
This example, ffmpeg sees the output is to be mp4 and assigns AVC + AAC streams to the output.
ffmpeg -i clip.avi clip.mp4 -
Thank you for the info. I will do some research and have a play.
Greg -
If you need batch processing you could try XMedia Recode.
Set Video to Copy and Audio to convert. You can set your own bitrates, channels etc.
Are there any tutorials to convert stereo MP3 to stereo AC3?
By rocky12 in forum AudioReplies: 10Last Post: 4th Sep 2011, 19:05 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
Does anyone know how to convert joint stereo audio back to stereo?
By robrosen in forum AudioReplies: 1Last Post: 2nd Aug 2009, 22:24 -
Convert DTS to Stereo
By gb_direwolf in forum AudioReplies: 4Last Post: 17th Mar 2009, 07:42 -
5.1VOB to 5.1AAC???
By ssj2_goha in forum AudioReplies: 2Last Post: 22nd May 2007, 03:57
